Old 05-15-2008, 03:46 AM   #1 (permalink)
ballorfall's Avatar
Exclamation car rumble/vibrations when idle?
so i just got my Si back from the shop after that fender bender last month. The total cost was around $2,600 to fix. I have a question for you guys. Does your car kinda rumble when it is idle at a red light in neutral? My rumble is really light but i can feel it in my lower back and hand if i rest it on the hand rest on the door. My GF says she can't feel anything but i can. Its not visible by any means. I forgot if it is normal for the car to have a slight rumble or vibration because its been a while. Do you guys feel anything on your car?
ballorfall is offline
Old 05-15-2008, 03:54 AM   #2 (permalink)
Whos The Whore NOW
07mugencivic's Avatar
Tony
how bad was the fender bender...did it move any motor mounts
Originally Posted by webby View Post
does this mean you're drunk?
07mugencivic is online now
Old 05-15-2008, 04:20 AM   #3 (permalink)
ballorfall's Avatar
No i dont think so. It was basically my right fender was replaced and bumper, he hit my front right corner, the hood wasnt damaged. maybe i should look at the motor mount?
Old 05-15-2008, 10:38 AM   #4 (permalink)
Duce2k's Avatar
I don't feel any vibration or rumble at idle, maybe it's your a/c kicking on and off, try it with the system turned off, even if it's just the fan. Also you might have some bad gas in there causing a rough idle
Duce2k is offline
Old 05-15-2008, 01:05 PM   #5 (permalink)
nayilsi's Avatar
with AC off
u are not supposed to feel vibration from anywhere other than the steering
nayilsi is offline
Old 05-15-2008, 01:27 PM   #6 (permalink)
F@#$ dyno numbers
Si2Typ3R's Avatar
Nate
I have experienced the rumble you notice. Mine comes and goes, mostly when the fan kicks on and off with the a/c. It's not major, but then again I do have 43k on my Si. Mileage will effect smoothness in idle as well. Maybe try some fuel system cleaner....?
"its incredible what a little more weight in the knob can do. Its so much easier getting it into gear it just slides right in."
Originally Posted by eXe View Post
697 posts....youre a nub whore. Youre like a budget asian prostitute
Si2Typ3R is offline
Old 05-15-2008, 04:53 PM   #7 (permalink)
ballorfall's Avatar
My car only has around 4k. I never put anything lower than 91 octane, last fill up was with mobil 91 octane although the gas was 1 month old because it was in the shop.
steering wheel vibrations datbacker59 Civic Coupe And Sedan 12 06-06-2007 01:21 AM
Exhaust rumble LoverOfCivics Mechanical Problems & Technical Chat 4 05-23-2007 02:05 PM
engine vibrations in my r18 Cornizzy Mechanical Problems & Technical Chat 1 12-19-2006 02:14 AM
Rumble sound? 06xy Mechanical Problems & Technical Chat 15 12-18-2006 11:13 PM
vibrations from rear speakers phantom-civic I.C.E., Electrical, Security, & Navigation 7 11-25-2006 08:09 PM
