PARTS (oreilly, advance, autozone, pep boys) store part number for the NGK plugs are
7746 and the NGK part number is IFR7G-11KS the spark plug gap is .044, make sure you gap it with a needle nose and avoid touching the electrode (it can break and it will break with too much pressure) and the EP3's spark plugs are another part number = 6994 (IZFR6K11) Last edited by R4DG; 05-14-2008 at 03:09 PM. |
Even if the plugs look the same, if they are different part numbers they could have different internal resistances (which could change your spark duration and spark temperature). And/or they could be a different heat range which could cause them to foul more easily (if they are colder) or cause detonation (if they are hotter).
In short, they may work, but they aren't the plugs which the engine is designed to use and most likely aren't optimal for your car. |
#8 (permalink) | |
#11 (permalink) | |
call NGK yourself "Customer Service hours: 8:30am - 6:00pm Monday-Friday EST tel: 1-877-473-6767 prompt #1 Technical Support hours: 8:30am - 5:00pm Monday-Friday EST tel: 1-877-473-6767 prompt #2" like i said, use a needle nose pliers and adjust the ground and dont use the circular tool to see what the gap is, use the gapping tool with the rings Last edited by R4DG; 05-15-2008 at 08:25 AM. |
#12 (permalink) | |
| Spark Plugs | jeremy0203 | Forced Induction And Nitrous | 10 | 01-02-2008 05:12 AM |
| Spark plugs? | The Shishpanik | Civic Coupe And Sedan | 0 | 10-17-2006 06:04 PM |
| HELP!!!!!!!! WHAT SPARK PLUGS FIT????? | dannyboy's06Si | Bolt-Ons And All-Motor | 5 | 08-29-2006 11:07 PM |
| Spark Plugs | martinez_josh | Bolt-Ons And All-Motor | 5 | 05-03-2006 10:32 PM |
| Spark Plugs | waross | Do It Yourself Articles | 1 | 03-11-2006 07:06 PM |
