Old 05-14-2008, 12:40 AM   #1 (permalink)
shawnono's Avatar
Shawn
Gas pump sensor..
When I fill my car up, I just leave the pump alone until it stops, which usually means that it is full, but my lately, I've been finding out that I still have 3 or 5 bars to be filled in after the fill up. What do you guys think is wrong? What can I do?
shawnono is online now
Old 05-14-2008, 12:48 AM   #2 (permalink)
shawnono's Avatar
Shawn
bump for help
Old 05-14-2008, 12:59 AM   #3 (permalink)
do you fill up at the same place every time?
dannn is offline
Old 05-14-2008, 01:00 AM   #4 (permalink)
shawnono's Avatar
Shawn
yes. I don't get what's up!
Old 05-14-2008, 01:01 AM   #5 (permalink)
PL_FA5_KT
t85konrad's Avatar
konrad T
well its not ur sensor it tyhe pump it all depends if the pump feels any back presure once it does it shuts off, it all depends on how u stick it in the hole LOFL sounds so wrong.
t85konrad is online now
Old 05-14-2008, 01:03 AM   #6 (permalink)
shawnono's Avatar
Shawn
Yeah, but I "stick it in the hole" as far as I always have.
Old 05-14-2008, 01:05 AM   #7 (permalink)
PL_FA5_KT
t85konrad's Avatar
konrad T
lol well just dont put it in so deep, its just tripping the pump next time u fill up, wait till it stop then take it out anf hit it agian, ull find that it wil keep on filling, i worked for a trucking place where er had gas pumps and i fixed them .
Old 05-14-2008, 01:09 AM   #8 (permalink)
shawnono's Avatar
Shawn
okay, Thanks!
Old 05-14-2008, 01:09 AM   #9 (permalink)
PL_FA5_KT
t85konrad's Avatar
konrad T
no probe but if it does continue doin that go see ur dealer.
Old 05-14-2008, 05:24 PM   #10 (permalink)
Dave
Some pumps are more sensitive to the pressure change and some pumps may try and feed the fuel a little too fast which causes it to build up in the filler neck and turn the pump off. Also if the pump is one of the type that reclaim the gas vapors that are being displaced inside your tank as you fill it and this mechanism gets plugged up, it can't "swallow" the gas vapors quick enough, causing pressure to build up in the tank and make the pump think you're full. If this happens I just back the pump up a bit or twist it a bit to break the seal.
OrdnanceMarine is offline
Old 05-14-2008, 05:25 PM   #11 (permalink)
PL_FA5_KT
t85konrad's Avatar
konrad T
^ exectly Mr. know-it-all lol j/p
Old 05-15-2008, 07:40 AM   #12 (permalink)
BigT's Avatar
You say that the gauge says less than full, but does it still seem that you are putting the same amount of gas in, or is it taking less gallons to fill up as well?
If you are getting less in, they I'd agree with the pump shutting off too early. If it seems like you are putting the same amount of gallons in but the gauge is reading less than full then you might have a bad fuel gauge sending unit in the tank.
BigT is online now
What grade of gas? All gas questions answered! **Merged all gas threads** clm10k Civic SI 866 07-06-2008 04:30 PM
Wife lucks out at the gas pump. Shemmy Water Cooler 44 04-24-2008 06:23 PM
what do YOU do at the pump? kuad Civic Coupe And Sedan 100 01-14-2008 09:33 AM
what is the best place for tilt sensor and motion sensor? a13x Garage 0 01-23-2006 11:01 AM
