Old 05-12-2008, 08:19 PM   #1 (permalink)
koukou0o2's Avatar
someone PLEASE HELP!!..My engine check came on!
well it all started when i bought a test pipe for my o6 civic si. i put it on with a defouler too and waited for 15 minutes to idle. it was great until next day when i took it to drive and suddently my ENGINE LIGHT CAME ON!..i was like omgs!! then i came back and undid everything and attacted it back on again and it still came on...CAN SOMEONE HELP ME?..
koukou0o2 is offline
Old 05-12-2008, 08:27 PM   #2 (permalink)
liquidr1's Avatar
Dustin
its prolly just throwing the code telling you that your CAT is not functioning properly.
If thats the case, it wont affect your performance any. You'll just have to deal with the anoying CEL
liquidr1 is offline
Old 05-12-2008, 08:30 PM   #3 (permalink)
koukou0o2's Avatar
if thats the case.do you knoe if theres a reset button to remove the engine check light?
Old 05-12-2008, 08:52 PM   #4 (permalink)
you can either go to a place with an obd 2 scanner to scan and delete the code or you can just simply disconnect the battery
k20kat is offline
Old 05-12-2008, 10:40 PM   #5 (permalink)
Jay4dnb's Avatar
Jay a.k.a. JDM AS FUK!!!
disconnect the negative cable from you r battery for a few minutes and you should be ok....
Jay4dnb is offline
Old 05-13-2008, 01:01 AM   #6 (permalink)
TWFA5FTMFW
0720Steve's Avatar
Resident Si Sedan Hater Hater
before you disconnect the battery to clear the code i would go to autozone and use the scanner to read the code. it is easy to look up the code online to find what the code means and get an idea of why. if you do, post it in here to get some advise on where to start.
what mods have you done lately and how is the weather? do anything crazy while driving?
0720Steve is offline
Old 05-13-2008, 02:05 AM   #7 (permalink)
SilverBulletGTP's Avatar
You should borrow a scanner and find out what the code is before you jump to conclusions or go removing the code.
SilverBulletGTP is offline
Old 05-13-2008, 08:34 AM   #8 (permalink)
boltuprite's Avatar
Gary
If you disconnect the battery, you'll have to re-program the radio security code.
boltuprite is offline
Old 05-13-2008, 10:35 AM   #9 (permalink)
If it is a cat-issue my guess is the CEL will come back again at some point.
If you want a test pipe it's something you'll have to deal with.
RWatters is offline
Old 05-13-2008, 10:51 AM   #10 (permalink)
galaxygrey13's Avatar
Ignacio
I got the cel too with the HFC. I disconnected the battery and it came off. Then I removed my Evo2 and after a few hundred miles it came back again last night. I think i will have to disconect my battery again.
galaxygrey13 is online now
engine check up ziwang55 Mechanical Problems & Technical Chat 1 12-04-2007 09:32 PM
check engine light Penguinizi Mechanical Problems & Technical Chat 3 09-08-2007 11:37 AM
Check Engine Light, No Cat. xilovelsdx Bolt-Ons And All-Motor 18 08-22-2007 07:49 PM
check engine light? b_waggs83 Mechanical Problems & Technical Chat 7 07-20-2007 10:06 PM
Check Engine Light - Tried everything, double check my install? Yodums Bolt-Ons And All-Motor 42 09-23-2006 11:58 AM
