Old 05-12-2008, 04:02 PM   #1 (permalink)
Post Order of maintenance minder schedule
Hello everyone,
Now I know to follow MM as per Honda and 90+% of you do but can anyone tell me the order of these A/B 1/2/3/4/5?
Like is it A1, B1, A2, B1, A3??
No idea, just curious... Thanks in advance all.
ilikemycivic is offline
Old 05-12-2008, 04:27 PM   #2 (permalink)
Holy Crap!!!™
NBPRudy's Avatar
Randy
It's pretty much random and is based on your driving habits.
If you look in your manual it will give you a break down of whats required depending on what comes up.
edit: or just look at the link you posted.
Originally Posted by ImTheVoiceOfGod View Post
I know it is possible, I see many people do it, but it wont allow me to post quotes in my signature.
Can someone webbyhelp me please
NBPRudy is offline
Old 05-12-2008, 06:07 PM   #3 (permalink)
Well I'm not sure how it can be "pretty much random" and "is based on your driving habits", both of those statements in the same sentence seem to contradict each other.
I know what is required as per the link I have posted, I just want to know the order in which they will happen.
Sorry if I wasn't clear the first time, thanks.
Old 05-12-2008, 07:48 PM   #4 (permalink)
It's a secret
fishmonger is offline
Old 05-13-2008, 02:09 AM   #5 (permalink)
SilverBulletGTP's Avatar
Generally it alternates between A and B each time. I change my oil every 5,000 km regardless of whatever the dealer or anyone on here says. An other way of checking is turning the ignition key on and holding the select/reset button for more than 10 seconds until it flashes. Then it will tell you the number and sub item. But make sure you wait until the display starts flashing otherwise you'll reset your minder, not that it matters if you change your oil every 5,000 Km.
SilverBulletGTP is offline
Old 05-13-2008, 12:52 PM   #6 (permalink)
Danielle
hi, i work at honda...
a is change engine oil
b is change engine oil and oil filter
1 is rotate tires
2 is replace engine air filter and cabin air filter
3 is replace transmission fluid
4 is replace spark plugs, although plugs are platinum
5 is replace coolant
danielle ryan is offline
Old 05-13-2008, 01:09 PM   #7 (permalink)
Danielle
also, the computer bases the calculation on driving conditions (weather, driving habits, etc) and then synchronizes it with one of the numbers to make it easier for the customer not to have to come back twice.
aggressive maintenance schedule waaden Garage 5 04-16-2008 10:10 AM
Maintenance Schedule and Pricing Menu striker_1818 Civic Coupe And Sedan 70 12-16-2007 02:28 PM
Maintenance Minder Question etcthorne Mechanical Problems & Technical Chat 7 12-07-2007 04:13 PM
where is the maintenance schedule? 2evolved Civic SI 4 06-13-2006 12:34 AM
Recommended maintenance schedule ? Rjc22NJ Garage 9 02-12-2006 07:40 PM
