Old 05-12-2008, 01:42 PM   #1 (permalink)
RReuphoria's Avatar
Donny
Amsoil MT fluid or OEM Honda?
I know I'm going to use some 0W-30 Amsoil synth oil in my next oil change (was using mobil 1). However, I wanted to replace my MT fluid also.
The only problem is, Amosil recommends using Honda OEM for some reason. Why is this?
From their website:
LUBRICANTS & FLUIDS
Engine Oil
Grade 1......All TEMPS
SAE 0W-30 Synthetic Signature Series Oil
SAE 5W-30 Synthetic Motor Oil
SAE 5W-30 XL Synthetic Motor Oil
All Temps......5W-30
Manual Transmission,.....GLS[1]
Fluids
Power Steering Fluid.....PS
Brake Fluid.....HB
Series 500 High Performance DOT 3 Brake Fluid
Clutch Fluid.....HB
1. Honda MT fluid, P/N 08798-9031
What should I do
RReuphoria is offline
Old 05-12-2008, 01:46 PM   #2 (permalink)
06NaviEX's Avatar
'08 HRP FA5
They only show that for the 08 Si's. If you look up the 06 or 07 Si, they list the MTF.
I'm running Amsoil MTF in my new 08, and the shifting is much improved!
Read the description for the Amsoil MTF, and it says it is recommended for Honda OEM MTF fluid replacement.
You will be fine!
06NaviEX is offline
Old 05-12-2008, 01:49 PM   #3 (permalink)
RReuphoria's Avatar
Donny
Think I'll be ok with 0W-30 since the weather here is like 100 degrees 24/7 during the summer time?
Old 05-12-2008, 01:50 PM   #4 (permalink)
Artie
I actually just put amsoil mtf in about two days ago its awsome.
rdee77 is offline
AMSOIL MTF fluid vs "new" honda MTF fluid AznSupastar Civic SI 128 06-27-2008 01:10 PM
Just changed to AMSoil tranny fluid leonphelpss11 Driving Experience 19 01-18-2008 05:16 PM
where to buy amsoil tranny fluid GlxyGry06Si Garage 16 09-05-2007 11:10 PM
Got AMSOIL tranny fluid put in today Quantum Mechanical Problems & Technical Chat 4 08-20-2007 05:41 PM
New MT fluid, shifting much better Quantum Mechanical Problems & Technical Chat 13 06-14-2007 05:50 PM
