Old 05-11-2008, 06:44 PM   #1 (permalink)
JF
Car Pulls Left
hi guys, my 07 si sedan has been pulling left when I hit the gas. I recently put air in the tires would uneven tire pressure cause this or is it something else. thanks
cruncherjf1 is offline
Old 05-11-2008, 06:56 PM   #2 (permalink)
michinsi's Avatar
Tom
Uneven tire pressure, Alignment. One or the other...or maybe both.
michinsi is offline
Old 05-11-2008, 07:08 PM   #3 (permalink)
FG2uner's Avatar
Mark
idk.... i just put my stockies back on yesterday after they got painted and my car is doing the same thing... i just got an alignment and the car wasnt pulling until i put my wheels back on. i checked the air in all 4 tires and its equal. i just got an alignment like i said. so i took the wheels back off and put them on again, i figured maybe i accidentally put it on crooked, but it still pulls left when i hit the gas and when i let off it straightens back out....
so i feel ur pain op...
FG2uner is offline
Old 05-11-2008, 08:00 PM   #4 (permalink)
Switch the front and rear tires and see if it goes away.
TrekRider is offline
Old 05-12-2008, 03:59 PM   #5 (permalink)
Nick Schmitz
Mine pulls off to the right and my tire pressure is all the same. How many PSI are you guys putting in yours?
But I just recently rotated my tires and it started to pull to the right, when I first got the car it did that too, then I rotated the tires and all was well. So I know it has something to do with the tires I have in front now. Must be misaligned slightly, any other thoughts?
Snickolaz is offline
Old 05-12-2008, 04:02 PM   #6 (permalink)
mine does that too goes to left when i hit gas . i got 07 si coupe
enerelt is offline
Old 05-12-2008, 04:06 PM   #7 (permalink)
michinsi's Avatar
Tom
Hrm that weird....check your alignment. I would guess the car is dog tracking due to the thrust angle of the car.
michinsi is offline
Old 05-12-2008, 04:32 PM   #8 (permalink)
Louis
check the tire pressure and also check the tread depth on the front two tires.if one tire is worn more than the other it will pull. our cars are very sensitive with the lsd. i had the same problem
firemen1641 is offline
Old 05-12-2008, 04:48 PM   #9 (permalink)
galaxygrey13's Avatar
Mines pull forward reallly realllly bad.
galaxygrey13 is offline
Old 05-12-2008, 06:38 PM   #10 (permalink)
FG2uner's Avatar
Mark
lol foreward?
FG2uner is offline
Old 05-12-2008, 06:40 PM   #11 (permalink)
SoCal07Si's Avatar
suuuuuuuuurrrrrrrrrrrrre it does
SoCal07Si is offline
Old 05-12-2008, 11:28 PM   #12 (permalink)
polar23's Avatar
Kris
i laughed at this really hard... in a nice way though...
polar23 is offline
Old 05-13-2008, 12:17 AM   #13 (permalink)
Jeff
alot of front wheel drive have the pulling, it's torque steering and it has something to do with the uneven lengths of the driveshaft.
ojefferyo is offline
Old 05-13-2008, 12:25 AM   #14 (permalink)
-j-
Try rotating the tires around. It happens. This will most likely get rid of the problem.
-j- is offline
Currently Active Users Viewing This Thread: 1 (0 members and 1 guests)
06 SI - wanders / pulls based on road smiley Mechanical Problems & Technical Chat 19 04-20-2007 10:01 PM
any one else 06 si feel like it pulls to the right shawnhpi Civic SI 41 08-04-2006 04:01 PM
Door Pulls jbswads Mechanical Problems & Technical Chat 4 06-19-2006 02:23 PM
Car Pulls to the Left on Accelleration Civic SI 06 Mechanical Problems & Technical Chat 10 05-12-2006 10:28 AM
man pulls turnpike toll prank webby Water Cooler 15 01-04-2006 11:55 PM
Powered by vBulletin® Version 3.7.0
