Hydrolock anyone??
Ok. I know I hear a lot of people here choosing a SRI instead of a CAI because you are worried about hydrolock, which is an understandable concern. But has anybody actually experienced it or know anybody who has with a properly installed intake? I mean, the car was designed with cold air induction in mind.
KOOPA TROOPA
Well first off, welcome to the site man.
![]() If I were you I would get an sri, especially with the way that we see such crazy rain from time to time here in Ft. Worth. Off the top of my head I can't think of anyone that I personally know that has hydrolocked, but I know that there was a thread here a while back about a guy that hydrolocked his fg2. It was so long ago that I don't remember where it is though. Offtopic question, do you go to school around here? Feel free to just hit me up via PM to talk. |
#6 (permalink) | |
Moderator
the stock intake is NOT a cold air intake. look directly to the right of your battery, you'll see a hose there. that's where the air is actually drawn from. here's a good diagram of what our intake tract looks like (bottom picture):
![]() however, it isn't a hot intake, either. the plastic of the tubing doesn't heat up much. as for hydrolock, a H22 hatch here in Wichita did yesterday. other than that, I know of three members that have hydrolocked... At least one of them was trying to file it on their insurance.the risk of hydrolock is low if you watch out for large quantities of water. just remember that you can't drive through flooded streets, and make absolute certain that if ANYONE else drives your car, they are aware of this and just as concerned about it as you are.
#7 (permalink) | |
Thanks guys. I didn't know that it was drawing air from the fendewell. I was under the impression it drew it from around the front bumper. Thanks for the diagrams. You are right about the rain around here, it gets pretty crazy at times, and it will probably get worse with global warming...lol. I don't remember if it was last summer or the one before where we got the most rain I ever seen in my life. I guess I will go with a SRI, it looks nicer under the hood with it in my opinion. One quick question. If I am going to completely remove the stock intake, will I need to remove the front bumper?
Charlie The Metal Head!
The whole Hydrolock issue I have ever seen was as others have said, driving through flooded streets or very deep puddles that the filter gets covered in water will suck in water and cause the engine to Hyrdolock. I had this concern on my 2002 Camaro Z28 when I had SLP's CAI kit for the car and never had a problem, yet I had heard people driving their camaros through flooded streets and sucked up water to hydrolock their engines. Same with the SSRA for the F-bodys as well. Whoever says that CAI will hydrolock your engine with just driving in the rain does not realize that driving through a deep puddle or flooded street, is the cause of the hydrolock where as not driving through a deep puddle or flooded street and just driving while in the rain will not cause the issue.... This is just my opinion though.. Just use common sense and you should be fine.
Charlie Last edited by dmnall; 05-11-2008 at 11:51 AM. |
#10 (permalink) | ||
Moderator
no. it's actually pulling the air from right under the top of the metal fender. in addition, the water would have to go down, into the resonator, through the maze, and then back up into the airbox and then through the throttle body and intake manifold. you'd need gallons and gallons, probably more than 5, to accomplish that. furthermore, there is a hole in the bottom of your stock airbox that allows water to drain from the intake. Finally, unless the water (as liquid, not steam) somehow gets past the filter element, your engine won't hydrolock. with a CAI, the whole end of the intake becomes submerged and then becomes a straw. unless there's a massive flood, I don't see the same thing happening with the stock box.
#11 (permalink) | ||
#12 (permalink) | |
Moderator
you actually don't have to remove the bumper. just remove the driver's side wheel, the fenderlining, one bolt from the resonator, and pull. It'll pop out. that's essentially how I removed mine.
#14 (permalink) | |
#16 (permalink) | |
2008 Honda Civic Si Sedan - Features - 197-hp, 2.0-Liter, DOHC i-VTEC® 4-Cylinder Engine |
#17 (permalink) | |
#18 (permalink) | |
Moderator
yes, honda markets it that way. the stock intake flows well, but the airbox shown in the top picture flows better. for that matter, most of the aftermarket intakes flow better than the stock box. this is because it was specifically designed to protect your car while giving you decent power and fuel economy.
Honda probably calls it a "cold intake" because it's not technically pulling air from the engine bay, it's pulling it from the top of the fender. if you don't believe me, go out and take a look at your stock intake... you'll see where it pulls the air from.
