Fuel gage stuck on "Full".....any experience/;thoughts?
I have a 2008 civic coupe EX, and recently filled up in Oklahoma and noticed: 1) the pump at the service station was running very, very slow and 2) the pump also recorded about about a .50 gallon MORE gas than I actually received, according to my average gas mileage (check every tank since new, now 9,500 miles) and this was the lowest MPG ever. And after that fillup, my fuel gage will not move off the full mark. Any ideas or thoughts?
I had a similar experience. I went to a gas station and the pump was realllly slow. Anyway, I drove almost 100 miles before I went down a bar. According to my calculations on that tank I got something like 40 mpg when I normally get about 28-30. I guess it just put in more gas than normal almost like it over-filled it. Just ride around for 100 miles or more maybe and see if it goes down. I wouldn't worry until then.
If the pump pumps slowly, the gas vapor has more time to evacuate the tank, while being displaced by fuel. Because the pump shut off works based off of the pressure of the venting fuel vapor, you will get considerable more gas in the tank (and potentially too much for proper ventilation once under way).
Because you have more fuel in the filler neck then normal, the gas gauge will stay on full longer then normal, as the gauge reads tank level and does not capture fuel in the filler neck. Then, since you are calculating gas mileage at the next fill up, assuming different pumps shut off at the same pressure reading and the pumps fill at the same rate, you will have an artificially high gas mileage reading. However, for this fill, you will have a very low rating due to the increased fuel delivery volume. So far, everything sounds fine. How many miles have you driven since filling up? Dan |
OK, Lilwolvy3, and Silver Slug........you guys nailed it correctly. Since it was filling so slowly, it apparently held more fuel than normal....and it finally came off the full mark at about 125 miles. So the next fill up and MPG should be fantastic........well sort of, it all evens out.
Thanks for the replies, you all saved me a trip to the dealer!! |
| My thoughts on the movie "Stealth" | Prototype | Water Cooler | 8 | 05-02-2008 12:40 PM |
| Had my first "near accident experience" this morning... | dcfife | Garage | 5 | 11-15-2006 08:12 AM |
| My "speedy" dealership experience! | Nomar06 | Driving Experience | 11 | 07-25-2006 08:27 PM |
