There is something up with my clutch pedal that really isnt ordinary..
- At times would make a huge squeak when i press the clutch pedal. It is coming from under the car and it sounds like if you pulled on the exhaust midpipe enough it would make the same "squeak". I was pondering if pressing the clutch pedal does something to pull against the exhaust section to make that noise but that sounds ridiculous. - I drove my friends FA5 and his clutch pedal is noticeably lighter, is there any reason for this? I own a FG2 and would believe we have the same engine/motor. BTW we both have an 07'. Any ideas people? |
Hmmm... i have an 06 sedan and i encountered a similar problem. My clutch was heavier than my brothers (also an 06 sedan) and i was getting a clicking sound+feel in my clutch as i would let it out. I took it to Honda, they changed my clutch pedal assembly, but the click still occurs. Much less often, but it still happens. The clutch is still heavy however. I remember seeing a thread about the squeaking tho, it also had videos for sound posted on youtube...
this "squeak" is one of the mysteries of the world
I have heard dozens of different theories and so-called reasons for the clutch sqeuak that sometimes don't even have anything do with the clutch. I get the squeak really bad too. It seems to be more prominent when i'm letting the clutch out slowly at low rpms. I definately don't think its the exhuast hanger because when i put the e-brake on and slowly let go of the clutch in first gear, i hear a squeak. No movement should = no hanger movement = no squeak but that's not the case |
here you go, this might help:
"Clutch" Squeak problem found.. |
#10 (permalink) |
I get the clicking sound with feel only in the warm months in the winter time it goes away. I think it's either clutch pedal rod lube breaking down when it's hot or something else. I stoped worrying about it when I realized it was temperature dependent.
| clutch pedal | SilentBob420BMFJ | Mechanical Problems & Technical Chat | 56 | 03-19-2008 09:17 AM |
| clutch pedal | bmcivic | Mechanical Problems & Technical Chat | 16 | 01-19-2008 09:31 PM |
| Clutch pedal squeaking | TJ06CivicLX | Mechanical Problems & Technical Chat | 21 | 12-22-2007 05:32 PM |
| Squeaky clutch pedal | usakicksass | Civic SI | 0 | 10-17-2007 07:58 PM |
| clutch pedal | amisher | Civic SI | 8 | 08-16-2007 02:47 AM |
