Old 05-22-2008, 12:37 PM   #21 (permalink)
Originally Posted by cruncherjf1 View Post
my second sucks it used to always grind or stutter and then go in but now sometimes when im rippin it, it just wont go in. i have to push the clutch in really hard wait and then jam it in. my 3rd gear sucks also it stutters going in and pops out sometimes. and reverse grinds alot unless i go really slowly.
You know there is a fix for your problem... You should take it back to the dealer and have them replace your 3rd gear...
carspidey is offline
Old 05-22-2008, 02:24 PM   #22 (permalink)
chrisng's Avatar
I have this problem too, its really notchy in like 2nd, 6th, and sometimes reverse doesn't engage. it's really starting to piss me off, but my third gear is fine, so i'm not sure what to do at this point. Anybody have any suggestions? I heard that you could change the manual transmission fluid and it iwll help should i try to get honda to do this under warranty?
chrisng is offline
Old 05-22-2008, 08:36 PM   #23 (permalink)
You should....
I already told them about this problem... I will take my car this weekend and let you know what happened....
1st to 2nd gear grind in VTEC!!!:( drumkid8 Mechanical Problems & Technical Chat 7 03-14-2008 01:08 PM
Shifting into 1st gear when at a stop... redpepSi Mechanical Problems & Technical Chat 18 10-10-2007 12:18 AM
problem shifting from 2nd to 3rd gear 7002iSciviC Civic SI 6 08-27-2007 09:32 PM
Having trouble shifting from 1st to 2nd nickester Mechanical Problems & Technical Chat 21 06-15-2007 10:29 AM
Hitting the wall between 1st and 2nd gear? MT incongruent Mechanical Problems & Technical Chat 48 04-25-2006 12:38 PM
