Old 05-08-2008, 08:39 PM   #1 (permalink)
windows rattle when cracked
as the title says, my 08 4dr si. when i have my windows cracked 1-2" they constantly rattle, loud. sounds like they are loose in the tracks. is there a bulletin on this, or anyone with this issue?
Yankees2519 is offline
Old 05-08-2008, 08:54 PM   #2 (permalink)
Steven
I get the same problem but i try to ignore it or just keep my windows all the way down.
08ASMSIdan is offline
Old 05-08-2008, 10:37 PM   #3 (permalink)
First post here, Whats up guys!
I had the same problem, took it to the dealer two times...
First time - Service writer told me that the tracks were dirty, so they cleaned them and added grease... (Sounds weird)
Second time - He told me some plastic part that holds the window might be broken, replaced the part...
The rattle is gone, but not fully. Only comes back when driving on a bad road...
I have an 08 4dr si too...
idontknow07 is offline
Old 05-09-2008, 09:27 AM   #4 (permalink)
welcome, and thanks for the info.
Old 05-09-2008, 09:28 AM   #5 (permalink)
Philly
i have the sameeeeee problem too....i just ignore it
Futurepr3 is offline
Old 05-09-2008, 10:27 AM   #6 (permalink)
Duce2k's Avatar
Sound deadening
Duce2k is online now
Old 05-09-2008, 07:41 PM   #7 (permalink)
I have a 07 civic si with the window rattle. Took it to the dealer and they fixed the rattle. Don't know what the exact fix was but I know they had to remove the door panel and know the door is hard to open.
rwb137 is offline
Old 05-09-2008, 07:47 PM   #8 (permalink)
I usually lower the window a little bit more (half open) and the rattle goes away.
rwb137: did you tint your windows? would the dealer say the rattle was caused by the tinting and not fix it?
daveeboy is offline
Old 05-10-2008, 01:09 AM   #9 (permalink)
I had the same problem. Had the window regulator replaced to fix the problem. The dealership didn't want to fix it the first time I complained about it. They came back with the line that the other SI on the lot made the same noise. I just told them looks like you have 2 to fix. I told them I could have saved around $18k if I wanted to listen to windows rattle. They replaced it and it fixed the problem.
zipn8gnsisedan is offline
Old 05-15-2008, 11:38 AM   #10 (permalink)
11 days old, '08 Si 4 door, and the L/F window has been rattling since day 1. Sounds like a snap when going over bumps, or even cracks in the road. Sounds like it's something hitting the glass, towards the ends of the door frame. With the window 1/2 way down, it's not there. Is this a bad regulator, or something else? I'd take it to the dealer, but don't have the time yet.
Any info would help. Thanks.
9900rpm is offline
Old 05-15-2008, 11:50 AM   #11 (permalink)
Jeff
both my front windows rattle when you crack it open a few inches the sound goes away when it's about half way or more. havent bother to take it in yet, wonder what they are gonna say about tint probably something stupid like "the tint caused it because it added extra weight to the guide and tracks"...lol
ojefferyo is offline
Old 05-15-2008, 12:03 PM   #12 (permalink)
I have window rattles too when the windows are cracked open like 3 to 4 inches. Afraid to take it to the dealer and get the car back with different problems or worse.
mugenhonda25 is offline
Old 05-15-2008, 12:08 PM   #13 (permalink)
Sounds like my old 91' mustang GT. I would expect that from a car thats 16 years old but not an 08.
I WOULD ****** LOSE MY MARBLES on the dealer if my window rattled
08civicman is offline
Old 05-15-2008, 12:26 PM   #14 (permalink)
eXe
210whp/150tq
eXe's Avatar
myg0t
Got the same problem. I usually just put my windows down or up
Originally Posted by illusionstwice View Post
if u havent seen black cars with CF hood, then u need to crawl out from under your rock. They are all OVER this damn site.
eXe is online now
Old 05-16-2008, 07:32 PM   #15 (permalink)
I know how to fix the window rattle. I couldn't figure out what the dealer did but recently found out that the bent to upper portion of my door frame so when the window rolls down there is tension on the window. I found this out because they bent it too much and was causing the door to close and open hard. Bent it back a little and i'm good to go.
rwb137 is offline
Old 05-16-2008, 07:33 PM   #16 (permalink)
Whos The Whore NOW
07mugencivic's Avatar
Tony
my did that too..until i got my visors
07mugencivic is offline
Old 05-21-2008, 01:23 AM   #17 (permalink)
leejc235's Avatar
I had a buzzing sound on my FA5 when the windows were not down all the way.
After I dynmated the doors, the buzzing went away along with other noises from the door.
leejc235 is offline
Old 05-21-2008, 02:22 AM   #18 (permalink)
ldawson77777's Avatar
They claimed they fixed this on mine by replacing the regulators (both windows), but they still rattle. I'll probably have to complain again. And my brand new sun visor rattles too...I swear they take parts out of one car and put them into another...
ldawson77777 is offline
Old 05-21-2008, 09:15 PM   #19 (permalink)
oh come on its not the worst thing that could happen. you are forgetting you drive a civic.
Old 06-03-2008, 12:31 PM   #20 (permalink)
Brandon Park's Avatar
Brian
Hey i see every SI has this problem same with mine i have an 08 4dr SI that was made in FEB 08, do you know what they did to solve the rattle.
Brandon Park is offline
Cracked Foglight!! honda_man12 Inside and Out 3 02-01-2008 05:43 AM
Open moonroof rattle + A pillar rattle civcracker Mechanical Problems & Technical Chat 5 01-28-2008 05:20 PM
Sqeaky Rattle From Rear Windows...Dealer says TSB for This WasabiPeas Mechanical Problems & Technical Chat 9 02-25-2007 10:56 PM
ECU cracked yet?? CivNick Civic Coupe And Sedan 3 05-29-2006 11:12 PM
