Old 05-02-2008, 12:02 AM   #1 (permalink)
hot upper radiator hose
hi there! newbie here. i recently replaced the radiator of my 06 civic sedan LX because of an accident. Today when i check my radiator I can see that the rad fab is not working at all. After some checking, i was able to find out that it is only that upper radiator that is hot. The lower radiator is not even hot. What maybe causing this issue...What do i have to do...
thanks in advance.
nelo is offline
Old 05-02-2008, 12:15 AM   #2 (permalink)
Bottle Fed!
WhiteSicivic06's Avatar
Ryan
Id first check into why your fan isnt coming on! You can check this by turning on your A/C,...the fan should turn on right away! You might have a stuck or damaged thermostat.
N2O TW FTW!
216 N/A 250.57 N2O
WhiteSicivic06 is offline
Old 05-02-2008, 02:08 AM   #3 (permalink)
'08 Civic Si
The thermostat won't open until it hits about 180F. The fan won't come on until the engine hits around 190F or so. If it's still not getting flow through it after a highway run I'd check that the thermostat is working. Usually they get stuck in an open position though... weird. You can test it by putting it in boiling water. You'll need a new gasket if you take the old thermostat out. May as well get a new one while you're at it!
What's you temp gauge showing? is it running hotter than normal?
rob76 is offline
Old 05-02-2008, 08:30 AM   #4 (permalink)
Kidekat's Avatar
Normally the upper radiator shoudl be hot, as it is coming otu of the block. The lower one should be warm-cold depending on the ambient temp, as it is carrying heat exchanged coolant.
Kidekat is offline
Will FD1 radiator Hose fit my FG1?? CivicKid19 Bolt-Ons And All-Motor 7 04-13-2008 01:04 PM
Replacing Radiator Hose PSU Pinoy PSU Mechanical Problems & Technical Chat 13 03-06-2008 05:18 PM
Steel radiator hose GlxyGry06Si Bolt-Ons And All-Motor 20 08-16-2007 06:14 PM
AEM SRI rubbing radiator hose??? chullen Bolt-Ons And All-Motor 2 02-28-2007 02:10 PM
issue with injen cai pipe and radiator hose eugenekim.net Bolt-Ons And All-Motor 6 08-16-2006 04:19 PM
