Old 05-01-2008, 11:51 AM   #1 (permalink)
Passenger Windows and Power Lock Button on 2006 Civix LX Broken?
I am trying to avoid going to a dealer to fix this, but I might have to if no one else has had this problem. First of all, none of the passenger windows work. (the button on the driver's side control panel for the passenger window lock is off). The window buttons at each passenger door do not work either. However, the driver's side window goes up and down, but the auto doesn't work. (I tried to reset it by putting the window down and then up and holding it for several seconds per the manual, but the Auto still does not work.) Also, the power lock button on the driver's side control panel doesn't work either. The FOB key works and the passenger side's power lock button works too. I've checked the fuses under the steering wheel for the power windows and passenger windows and all seem to be ok. Any suggestions? Do I have to open up the door paneling? Is that difficult? Do you think it is wiring?
Thanks so much.
mck28 is offline
Old 05-01-2008, 01:30 PM   #2 (permalink)
forvisor's Avatar
It doesn't sound like a fuse or wiring issue if the driver’s buttons work. Bad switch on the passengers windows? I don’t know maybe someone else can shed some more light on this situation.
forvisor is offline
Old 05-02-2008, 02:40 AM   #3 (permalink)
Well, the driver's side button works only for the driver's side window. it doesn't control the passenger windows either.
mck28 is offline
avic-d1 navi open button broken? indoxbo1 I.C.E., Electrical, Security, & Navigation 0 05-01-2008 12:00 AM
Broken Center console button bacs vhx1 Mechanical Problems & Technical Chat 13 11-14-2007 09:36 PM
2006 LX Sedan needs more power! Rommy Bolt-Ons And All-Motor 38 07-26-2007 12:52 PM
Broken passenger mirror tommyroo Mechanical Problems & Technical Chat 13 04-16-2007 06:38 PM
Trunk Lock broken Coop Mechanical Problems & Technical Chat 17 04-16-2007 12:48 AM
