Old 04-30-2008, 11:08 PM   #1 (permalink)
fern2021's Avatar
trunk latch release not working
anybody out there having issues with the trunk release lever? mine feels like it's stuck or something, and my key won't turn when i try to unlock the latch. opens just fine when i use the remote though.
fern2021 is offline   Reply With Quote
Old 05-01-2008, 09:23 AM   #2 (permalink)
formal but likes to party
Mabuz's Avatar
When I installed my fog lights, I had to pull up the trim piece that covers the driver's side door sill area/trunk release lever. When I reinstalled that piece, I didn't realign the trunk release lever with the metal tumbler thing (or whatever it is inside) and had the same problem.
So, have you had that trim piece moved for any reason recently?
You can check the trunk release lever out as follows:
-There's a little cover piece that you can pop off w/a flathead screwdrive on the top of the release lever "bump".
-There will be a screw under that cover that you can take out, and then play around with getting the plastic arm from the lever to align with a metal tumbler type thing.
Mabuz is online now   Reply With Quote
trunk latch wont align properly on my SEIBON trunk. Epileptic Mechanical Problems & Technical Chat 0 04-26-2008 04:03 AM
Unable to open trunk by using Trunk/Gas Latch. pxstar Mechanical Problems & Technical Chat 12 04-03-2008 02:35 AM
FOB Trunk Release stopped working Honda refusing to fix. MaXaZoR Mechanical Problems & Technical Chat 14 02-12-2008 11:57 PM
trunk release from inside stopped working... SIg Mechanical Problems & Technical Chat 10 12-18-2007 09:43 AM
How does Trunk Latch work? jjohan35 I.C.E., Electrical, Security, & Navigation 12 07-16-2007 05:11 AM
