Old 04-30-2008, 01:19 AM   #1 (permalink)
Robert
is it posible to change the transmission ???
I really don't know much about cars mechanics but i really want to know if i could change my honda civic ex 06 transmission for de honda civic si transmission what are the step in doing so(if that is posible)
RobDane is offline
Old 04-30-2008, 01:20 AM   #2 (permalink)
Robert
i really would aprecciate the help since more knowledge its more understanding!!!thanx
RobDane is offline
Old 04-30-2008, 01:24 AM   #3 (permalink)
chugiboi's Avatar
chue hang
same year?
chugiboi is online now
Old 04-30-2008, 01:28 AM   #4 (permalink)
chugiboi's Avatar
chue hang
if so then it should be a no.
why? because the R18 and the K20z3 doesn't share the same bolt pattern for the transmission, and the R18 has a 5 speeds tranny while the K20z3 has a six speeds.
but hey, anything is possible with the right tools and modifications.
Old 04-30-2008, 03:55 AM   #5 (permalink)
brzrkr626's Avatar
no you can't.
brzrkr626 is offline
Old 04-30-2008, 11:49 AM   #6 (permalink)
DTNguyen107's Avatar
Not without a K20. Go get one now.
DTNguyen107 is offline
Old 05-01-2008, 03:27 PM   #7 (permalink)
Robert
Oh!! thanx for the help, know my question would it be a good idea to buy a k20 for my civic 06 ????
RobDane is offline
Old 05-01-2008, 03:34 PM   #8 (permalink)
volvo9's Avatar
Andrew
With modern cars it's easier and cheaper to trade your car in for the type you want. What you are trying to do is make a 1/2 Si out of your standard Civic. Just get an Si, it'll be cheaper.
If not then you will need to transfer the engine, transmission, ecu, and engine wiring harness over, plus the under dash wiring probrably won't match up to the ecu and that may need to be swapped also. A lot of work, and a lot of money.
With older cars it was no big deal because there where not many computers. I swapped my rwd Volvo from an auto to a manual in a weekend, but the auto wasn't computer controlled so nothing else needed to be touched besides teh transmission.
volvo9 is offline
Old 05-01-2008, 07:54 PM   #9 (permalink)
Robert
Oh well then i guess i should be doing mods instead thanx for the help i really needed to clear my mind about that and for thanx for the info!!!
RobDane is offline
Old 05-01-2008, 10:39 PM   #10 (permalink)
slow4drsi's Avatar
it's gonna be cheaper and smarter to just trade your ex for an si, than do the swap.
slow4drsi is offline
Transmission Change!! SiiSSick Bolt-Ons And All-Motor 19 03-12-2008 12:23 AM
Transmission fluid change catchx34 Mechanical Problems & Technical Chat 9 03-24-2007 10:33 PM
Need to change my manual transmission fluid to that syncro from royal purple 1.8L FG KiDd Civic Coupe And Sedan 2 03-22-2007 12:44 PM
Transmission fluid change results ADewan Mechanical Problems & Technical Chat 0 12-04-2006 09:23 PM
