Old 04-28-2008, 11:10 PM   #1 (permalink)
ēmuch FAP... overload
ryryninja's Avatar
205whp 147tq :D
Alternator Going bad... AGAIN
So the last few days I've noticed that when ever my radiator fan cuts on, its like my cars electronics surge and power off and then right back on. Mostly just the radio. It got worse though, my headlights and fogs cut off then back on. One bulb didn't cut back on so i pulled over at McDonalds to see whats going on.
Now my positive terminal connector could be replaced as it doesnt fit as snug as it used to. But I know its not coming on and off the battery post when I'm driving. I just got the alternator replaced around 71k miles.... i'd hate to have to bring it in again for the same stupid reason though it looks like I might have to
Only extra electronics i'm running are 2 hid kits and it still does it during the day time when the lights are off. Ground wire kit which shouldn't do anything negative and a voltage stabilizer. No aftermarket system or anything.
Any other ideas of what it might be? Gonna call the dealership tomorrow, sigh...
ryryninja is online now
Old 04-28-2008, 11:23 PM   #2 (permalink)
radiocontrolhead's Avatar
Danny
It could very well just be your HID headlights.
radiocontrolhead is offline
Old 04-28-2008, 11:30 PM   #3 (permalink)
Kill Your Self Krew
Zeuceone's Avatar
Looks like the dealer set you up on your last visit.
is Missy a squirter?
Zeuceone is online now
Old 04-28-2008, 11:30 PM   #4 (permalink)
ryryninja's Avatar
205whp 147tq :D
I hope not. That would really suck, just read up more and more and more its pointing to a failing alternator.
Old 04-28-2008, 11:31 PM   #5 (permalink)
ryryninja's Avatar
205whp 147tq :D
Well they are gonna be replacing it for free then
Old 04-28-2008, 11:32 PM   #6 (permalink)
ryryninja's Avatar
205whp 147tq :D
I also failed to mention that a few weeks ago on the stock battery, I woke up one morning to find out the car wouldn't start. Had to jump it because the battery was dead. I didn't leave any lights on or anything like that. I've gotten a new battery since then so I know it can't be that.
Old 04-28-2008, 11:33 PM   #7 (permalink)
udumkid's Avatar
Rene....
Didnt you get that buddy club stabilizer box a few months ago>?....
udumkid is offline
Old 04-28-2008, 11:34 PM   #8 (permalink)
volvo9's Avatar
Andrew
Could also be your battery. If it's getting weak then all of the electrical load of devices (esp high drain ones like rad fans) is getting put on the alternator, which can't deal with high current peaks alone.
If you have had two alts fail so soon then you must be overpowering them with the stuff you added and killing it prematurely.
EDIT: Nevermind about the battery thing, you just posted and said you got a new one.
volvo9 is offline
Old 04-28-2008, 11:35 PM   #9 (permalink)
ryryninja's Avatar
205whp 147tq :D
yeah, but i doubt that does anything with holding a charge. My car acted like this a few times before I got the alternator replaced the first time. At that point I was only running 1 HID kit and thats it.
Old 04-28-2008, 11:36 PM   #10 (permalink)
ryryninja's Avatar
205whp 147tq :D
I'm gonna use the voltmeter from work tomorrow when I get into the office. See if I can find the culprit. The first alternator failed at 71k. I've only had this one for about 16k almost 17k
Old 04-28-2008, 11:48 PM   #11 (permalink)
udumkid's Avatar
Rene....
Bring it by...I will run a charging system test...
udumkid is offline
Old 04-29-2008, 11:52 AM   #12 (permalink)
ryryninja's Avatar
205whp 147tq :D
Went to a shop this morning to test the charging system, family friend I guess you could say. Said my charging system is completely fine.
Looks like I won't be needing a new alternator Figured out that the positive terminals on the HIDs aren't seated fully against the post. After readjusting them a bit making sure everything sat FLUSH, I let the car sit thru a few cycles with nothing on at first. Passed that test. Then had the radio and defroster on.. once again it passed. Then the real moment of truth, HIDs both sets, radio and defroster on.... and it passed again. I drove with my HIDs and everything on and for about 30 miles to really test it. Came up to a few lights and when the radiator fans cut on, nothing shut off The idle is a bit rough though, i'm sure the ECU reseted a few times during this whole ordeal. Gonna relearn the idle later today and hopefully all is well.
I'm probably going to replace the positive terminal on the car's harness itself first. Its pretty worn and doesn't snuggly grab the positive post as much as it used. If that doesn't fix it then I'm going to replace all three positive terminals on the HIDs and voltage stabilizer.
Old 04-29-2008, 01:48 PM   #13 (permalink)
06CivEXJon's Avatar
Jon
I noticed that the alternator is very weak in our civics and the battery. Replacing both with higher more powerful units should solve a few issues.
06CivEXJon is offline
Old 04-29-2008, 01:51 PM   #14 (permalink)
Dont get eaten!!
Phalanx's Avatar
Ski-Free Monster
Ive noticed my car seems to be having a little hesitation when trying to turn on the past few days. Not sure why this is happening.... maybe its the alternator?
"A car never breaks. It presents us with opportunities to upgrade."
Phalanx is offline
Retrofogs and a dirty Si. Bad, bad, bad(56K nono) atruhondagrl Introduction & Pictures 106 04-09-2008 01:16 PM
Bad Trans? NO NO, Bad MTF! Use GM and shift like butter. 07 Figi Blue Si Mechanical Problems & Technical Chat 5 08-17-2007 06:11 PM
Alternator whine basmoq I.C.E., Electrical, Security, & Navigation 4 10-11-2006 06:15 AM
My new HO alternator Phlipcyde I.C.E., Electrical, Security, & Navigation 20 10-03-2006 04:20 AM
HO Alternator CNUco2007 I.C.E., Electrical, Security, & Navigation 2 09-19-2006 07:46 PM
