Old 04-19-2008, 03:06 PM   #1 (permalink)
innrfusion's Avatar
Fuentes
Installing A Greddy Exhaust... Need Help!!!
hey guys, im here kinda stumped. im trying to remove the stock exhaust pipe and there are 3 bolts that look oxidated that connect to the catalytic converter. this means i cant move them at all. iv been trying for the past half hour to wrench it off. i need help guys, any one done this to their car before? what did you do???
innrfusion is online now   Reply With Quote
Old 04-19-2008, 03:07 PM   #2 (permalink)
Supreme Pizza!
Izzy's Avatar
WD-40? Air tools?
Old 04-19-2008, 03:24 PM   #3 (permalink)
innrfusion's Avatar
Fuentes
wd40 yes...air tools....no lol. what do u think//
Old 04-19-2008, 03:33 PM   #4 (permalink)
FGJake's Avatar
Jake
WD40 and elbow grease. Maybe a cheater bar if you really can't get them off. Worst case scenario, you strip/break the bolts and have to make a run to the hardware store.
FGJake is offline   Reply With Quote
Old 04-19-2008, 03:35 PM   #5 (permalink)
Were the bolts hot when you tried to remove them? If not try running the car for a few minutes if you can, when I took my muffler off the bolts were tight so i just heated them up and they came right off. Hope this helps
jpv027 is online now   Reply With Quote
Old 04-19-2008, 03:35 PM   #6 (permalink)
wd-40 or pb blaster. if you still cant get htem off, then you need air tools or worst case is to have them torched
Si_Jeff is offline   Reply With Quote
Old 04-19-2008, 04:00 PM   #7 (permalink)
innrfusion's Avatar
Fuentes
ok i turned on the car and heated it up...nothing. its almost like it was welded on!!! this shit is driving me nuts. i used wd40 too ....dont tell me im gonna have to get this torched
Old 04-19-2008, 04:20 PM   #8 (permalink)
how old is ur car and mileage? i just did mine a 2 weeks ago and i didn't need to torch it, my car is 1 yr. and 4 months 15k miles. if you still cant get that off, maybe you might have to get it torched.
Old 04-19-2008, 04:23 PM   #9 (permalink)
innrfusion's Avatar
Fuentes
ok here r some pictures....what u guys think????
Old 04-19-2008, 04:24 PM   #10 (permalink)
innrfusion's Avatar
Fuentes
iv got 8700 miles on it...its 8 months old...
Old 04-19-2008, 04:29 PM   #11 (permalink)
the bolts don't look like they're stuck in there, those are cleaner than mine, lol . try to get a long wrenc or use a bar if you have one, they should come off looking at your pics. you need to take off the nuts only, then just reuse those rectangular bolts.
Old 04-19-2008, 04:45 PM   #12 (permalink)
Supreme Pizza!
Izzy's Avatar
Let the WD40 sit for a bit, then a breaker bar would be beneficial, as people are saying.
Old 04-19-2008, 04:55 PM   #13 (permalink)
02civicsi's Avatar
I am the Juggernaut!!!
Torch time.
02civicsi is offline   Reply With Quote
Old 04-19-2008, 05:02 PM   #14 (permalink)
SIis4ME's Avatar
ROMULUS
I just did my Skunk2 this after noon and I can tell you, you are not taking those off without a torch super heat the nuts and they come off easily and then you will need to super heat the corners of the Cat to knock out the the factory bolts for new bolts. Torch time dude or you will break the bolts and cause yourself many problems.
What are you doing this on a Coupe or Sedan?
SIis4ME is offline   Reply With Quote
Old 04-19-2008, 05:12 PM   #15 (permalink)
02civicsi's Avatar
I cringed @ the first pic as soon as I saw it.
Old 04-19-2008, 09:14 PM   #16 (permalink)
Uncle_Ruckus's Avatar
I had the same problem, I didn't even have to use a full acetylene torch, just one of the small propane ones for about 10 min per bolt, worked great. However go buy some new nuts and bolts now (preferrably stainless) for when you put your Greddy on...I installed the Evo2 and I love it. Btw, take your cat heat shield off too, you'll have to eventually.
Uncle_Ruckus is offline   Reply With Quote
Old 04-19-2008, 09:32 PM   #17 (permalink)
Agnt004's Avatar
Greg
Use a breaker bar and it will come off easier.
Agnt004 is offline   Reply With Quote
Old 04-20-2008, 01:15 AM   #18 (permalink)
innrfusion's Avatar
Fuentes
yo every body thank you for your help, we wd40'ed it all day lol. got a longer wrench and the boltsame off...maybe i should do a diy since i took pics lol.
Old 04-20-2008, 01:24 AM   #19 (permalink)
02civicsi's Avatar
Good to hear you got it taken care of. Now go forth & like no other.
Greddy Exhaust Hayaku Kenji Bolt-Ons And All-Motor 13 08-23-2007 11:43 PM
Installing my Skunk2 exhaust a few Questions ! Will06SI Bolt-Ons And All-Motor 10 07-24-2007 07:45 PM
Installing/driving impression comptech Header and exhaust Sirbelch Bolt-Ons And All-Motor 17 04-04-2007 07:37 PM
installing exhaust ??????? soymilk Bolt-Ons And All-Motor 10 11-15-2006 11:58 AM
Greddy Evo2 exhaust VS the DC Sports Exhaust shadowone Bolt-Ons And All-Motor 2 05-29-2006 03:19 PM
