Old 04-14-2008, 04:30 PM   #1 (permalink)
JDM suspension
sup guys, wanting to see if you could help a noob, im wanting to know if fa's can use fd2 suspension as far as dampers and springs, i thought i read some where that you couldnt, but wanted to make sure and if you cant what is it thats different? thanks in advanced
jdmhondafreak is offline   Reply With Quote
Old 04-14-2008, 05:01 PM   #2 (permalink)
dragonzsoul's Avatar
Brandon
i thought you could? i don't see why not. i think even FG's can? haha i guess i'm a noob too :P
dragonzsoul is offline   Reply With Quote
Old 04-14-2008, 05:02 PM   #3 (permalink)
Supreme Pizza!
Izzy's Avatar
You can use them. I think one brake (?) tube is not aligned the same, IIRC. But, that's easily taken care of.
Old 04-14-2008, 05:05 PM   #4 (permalink)
is stuck at work...
SiliconX's Avatar
Eric
That's correct.
(Picture posted by Highrev in the sticky thread)
The Wheel sensor harness clip labeled "A", the bracket it clips to is not in the same spot, so I just attached it to the bracket with a ziptie (a little loose). Other than that, it's a straight bolt in.
SiliconX is offline   Reply With Quote
Old 04-14-2008, 05:11 PM   #5 (permalink)
trickyazn's Avatar
how come highrev or some suspension guru's keep posting that they wont work with fg or fa bodies? they say itll fit but doesnt mean its right. also does this mean fd coilovers will fit?
trickyazn is online now   Reply With Quote
Old 04-14-2008, 05:14 PM   #6 (permalink)
Supreme Pizza!
Izzy's Avatar
Likely because it's valving and spring rates aren't the ideal, especially for the FG. But, I'll wait until Greg actually posts to hear what he says of them.
Personally, I thought that since the rear rates are stiffer than the FG's, then the car would rotate easier because of the decrease of weight we had over our rear wheels over the FA5/FD2.
Old 04-14-2008, 05:29 PM   #7 (permalink)
TeamBadger's Avatar
I also think the FD rear dampers are 30mm longer than the USDM.
TeamBadger is offline   Reply With Quote
Old 04-14-2008, 05:50 PM   #8 (permalink)
Brandon
longer? that's weird
Old 04-14-2008, 07:56 PM   #9 (permalink)
nice guys thanks for the info keep it coming this is what i eventually want, i found a picture of these dampers and springs on the japan honda website as an accessory, i think its the type r's "hfp" style suspension upgrade (as if it needs it) anyways i figure save up for this here's a link its the top set that i want japanparts.com : PARTS DATABASE
heres hondas website Honda | Honda Access | CIVIC TYPE R
Old 04-14-2008, 07:58 PM   #10 (permalink)
Brandon
what does it mean by there's a switch inside the engine room? did they mean engine bay? and how would you access the "switch"? i assume they meant the rebound adjustment, but in FGs, the top of the coils aren't exposed... are they in FA/FDs? if so, you guys are lucky..
Old 04-14-2008, 08:01 PM   #11 (permalink)
fa's are, after removing all that plastic covers :) heh
Old 04-14-2008, 08:10 PM   #12 (permalink)
Brandon
LOL same as FG's then.. that's so misleading.. oh, just twist the knob and you can adjust the suspension.. when i get coils, i have to get EDFC..
JDM FD2 Access Modulo Suspension FastTimesAtFGHigh Suspension and Brakes 23 05-15-2008 10:21 AM
Comparison between HFP (states) and HFP (JDM) Suspension No. 7 Suspension and Brakes 2 04-06-2008 01:09 PM
HFP suspension,fits the FD1 (JDM) civic ? xheartcore_boyx Suspension and Brakes 0 03-21-2008 05:58 AM
JDM Feel's Suspension FD2 FastTimesAtFGHigh Suspension and Brakes 8 02-15-2008 03:38 PM
Where to get the original JDM red rear emblem for my JDM sedan civic ?! xheartcore_boyx Inside and Out 34 02-12-2008 07:40 PM
