Old 04-14-2008, 12:59 PM   #1 (permalink)
slow4drsi's Avatar
oil question
hi peeps.I currently using mobil 1,and my oil minder is 50% .So i check my dip stick it's just a little above the 1st circle is this normal. i notice a little oil spill at the filter i prolly didn't put it that good or it's just prolly a spill from the last oil change or i'm just over reacting.Anyway do you think that's above the 1st circle is normal for 50 % oil minder.I got 1000 miles more before 3000 miles thank you.
slow4drsi is offline
Old 04-14-2008, 01:04 PM   #2 (permalink)
Leonard1818's Avatar
Leonard
So basically what you're saying is that in 2000 miles, you are just above the lower mark?
Did you do your own oil change?
Can you confirm it was at the top dot when it was changed?
Do you drive hard alot?
How did you break in your car?
Leonard1818 is offline
Old 04-14-2008, 01:13 PM   #3 (permalink)
slow4drsi's Avatar
Can you confirm it was at the top dot when it was changeyead?
yeah i went 3 times at the dyno this month and it's a little over the low mark and i got 1000 miles more to go.
Old 04-14-2008, 01:34 PM   #4 (permalink)
galaxygrey13's Avatar
Ignacio
It happens to me as well. I drive hard as well. just put in a quart of mobil 1 and you should be fine until you are scheduled for your next oil change.
galaxygrey13 is online now
Old 04-14-2008, 01:39 PM   #5 (permalink)
slow4drsi's Avatar
it's just weird i though mobil 1 last better than conventional oil . i think reflash is the problem and my heavy foot , it's just i'm worried cause my car only has 8000 miles,and just over the low oil with 1000 miles to go.
Old 04-14-2008, 02:17 PM   #6 (permalink)
volvo9's Avatar
Andrew
Not if the engine is burning it, any oil will dissapear then.
volvo9 is offline
Old 04-14-2008, 02:37 PM   #7 (permalink)
slow4drsi's Avatar
so you saying my motor is burning oil allready? 8000 miles.
Old 04-14-2008, 02:44 PM   #8 (permalink)
Ignacio
I think its normal. Mines does it.
Old 04-14-2008, 02:46 PM   #9 (permalink)
slow4drsi's Avatar
but youre boosted right?
Old 04-14-2008, 03:40 PM   #10 (permalink)
Leonard
I heard it's relatively normal for these motors. My RSX-S burned it a lot. Depends how you drive it I guess. Top it off and keep an eye on it.
Old 04-14-2008, 03:50 PM   #11 (permalink)
Johnold's Avatar
John
I've read alot of this "burning oil" and I have to admit, I have no idea why you guys say that. My Si doesn't burn or eat oil. I check my oil level and it's fine. Cold, It always says that it's a bit over the mid hole. Hot, it says it's a pinch below the FULL hold mark. I do all my own oil changes and it's always the same all the time. I put 5 FULL Qts of oil and it never burns or lowers itself. I don't know why your cars are burning your oil.
Johnold is online now
Old 04-14-2008, 04:17 PM   #12 (permalink)
Ignacio
No im not boosted. I wish.
Old 04-14-2008, 04:29 PM   #13 (permalink)
volvo9's Avatar
Andrew
Could be, if it was full when it was changed and it's not leaking, then it's burning it. Seems to be a semi common topic here, and with the RSX guys.
Mine didn't burn any either. Changed my M1 out with 6,500 miles on the oil and 10% on the maintenance minder and the level was still fine.
volvo9 is offline
Old 04-14-2008, 07:03 PM   #14 (permalink)
Johnold's Avatar
John
^ yeah, I don't know whats going on with some of these Si's burning oil but that CAN'T be good.
Old 04-14-2008, 08:23 PM   #15 (permalink)
slow4drsi's Avatar
it's been leaking by the oil filter , it seems dry now . i guess i did a crappy change oil and used a crappy oil filter.I just did a oil change and hope that's it.I guess i just really make the motor work hard this couple of weeks.
Old 04-30-2008, 09:36 PM   #16 (permalink)
EuphoricRhythm's Avatar
i have always been able to add a whole quart after 2000 miles on my si
But yea, thats what ive been reading too is that alot of k20's burn oil.
EuphoricRhythm is online now
Abnormal engine oil levels after changing to synthetic oil?? Si-aficionado Mechanical Problems & Technical Chat 35 08-09-2008 07:48 AM
Oil changed, but oil life won't reset!! Plz help!!!11 MurderedOut08Si Mechanical Problems & Technical Chat 4 03-21-2008 07:39 PM
Oil Sandwich Plate & Oil Filter Relocation Kit blueroadster Forced Induction And Nitrous 0 06-13-2007 01:39 PM
Is your dealer putting in the wrong type of oil, durring your oil change? Markstudy Garage 4 10-30-2006 08:08 AM
Lucas Oil fuel treatment and Sythetic Oil Stabilizer - Results Janizary Garage 3 09-02-2006 10:41 PM
