#241 (permalink) | |
while you might think it's a totally faulty part, there's a large potential that the issue stems from a manufacturing defect on the part itself that might be within manufacturing tolerances. it could be something as simple as 1/1000th of an inch difference in how something is machined (or even as close as 1/10000th). the original parts might all be within the previous tolerances, but you might have a few defects in the parts as always happens in manufacturing. those that have the issues, might have something that's out of whack by that little, and those that don't might have something that's within the tolerances, and is a little more lose than the ones with problems... it's a guess. what says that it's not a total recall... is that not all vehicles are effected by it.
2008 Honda Civic Si Sedan Fiji Blue Pearl ![]() FBP Crew #00 FA Crew #000 2007 Honda CR-V EX-L AWD Whistler Silver Metallic ![]() HondaSUVForums Member |
#244 (permalink) |
ESPAŅA SIEMPRE!
You exceeded the mileage quota for the warranty? Then I suggest you call up Honda America and open up a case number. In most cases, they'll do a "goodwill" consideration and perform the necessary repairs free of charge. But you need authorization from head office first.
#245 (permalink) |
Should I take off my comptech short shifter before I take in my Si?
And it states: "Drive a known-good vehicle under the same conditions as the customer's complaint, and compare the shift quality. If the customer's vehicle has noticeable shift quality probelms, replace the 3rd gear set." Does the above statement mean they have to replicate the 3rd gear grind/pop out for it to be fixed? Thanks. |
#249 (permalink) | |
"Out of warranty: Any repair performed after warranty expiration may be eligible for goodwill consideration by the District Parts and Service Manager or your Zone Office. You must request consideration, and get a decision, before starting work." |
#250 (permalink) | |
I am wondering the same thing... i have a grind in second and third.. also sometimes locked out of first at a dead stop |
#252 (permalink) | |
Every single part, fabricated in the same machine, is different. A good example would be the computer processor industry. After years of fine tuning the fabrication process, they get maybe 80% to 90% of the chips that pass the spec and is sold as core2dual.. the remainder 10%-20% is sold as something else. Maybe as single core or as a chip that's runs at slower clock. Either Honda redesigned the 3rd gear, that's less sensitive to the manufacture process, or they set a tighter specs for the part (lower tolerant). |
#253 (permalink) | |
Hidy ho neighbor
Honda made a mistake, and the result is an intermittant shifting problem. The TSB states that they have to replicate it before they will fix anyone's transmission. I would like if they would also provide for the instance where a customer states they have the shift problem, but the dealership cannot replicate it. In this case -- after say 5 attempts, they agree to repair the transmission. However, if they do not find any defective components, the customer pays for the repair. This would discourage the customers, who don't really have a problem, from wasting their time, and it would allow a customer like me, who has this defect, to get their transmission fixed without incurring lost work time due to bringing their car to the dealership over and over and over and etc. I can see that I will get stuck with this piece of crap problem that Honda caused, because I will get discouraged from having to bring it in for them to replicate without any success. Maybe that's what they're hoping for. ![]()
#254 (permalink) | |
Hidy ho neighbor
#255 (permalink) |
Go Gators!
Jesus people with the 5 speed manuals this has nothing to do with your cars. If your having problems its either you or your specific car, take it to the dealer, or see self about shifting issues.
IMV Films
Vehicular Lunacy at its Finest Firestrife's Nighthawk Wonder Gainesville/UF Guys check in here! |
#256 (permalink) | ||||
#258 (permalink) | |
How can they decide if a part is infact faulty or not? If this was true, this issue would of been spotted in the first placed and corrected before going into production. It is not my fault the issue is intermittent. All I know is the issue exists on my car, but does not happen everytime I shift. This should be enough grounds to cover a fix. |
