LinkBack (4) Thread Tools Display Modes
Old 04-13-2008, 10:17 PM   #181 (permalink)
jackolee's Avatar
wow im going to go to my dealer asap...
should i make apointment or just go in there?
jackolee is offline
Old 04-13-2008, 10:35 PM   #182 (permalink)
My5tiC4L's Avatar
Trade in here I come... hopefully.
My5tiC4L is offline
Old 04-13-2008, 11:00 PM   #183 (permalink)
michinsi's Avatar
Tom
This is a recall right? Would they fix the problem if the car is modded? I only have an intake...:)
michinsi is offline
Old 04-13-2008, 11:04 PM   #184 (permalink)
'08 Civic Si
My VIN is 8H200379. I have an 08 sedan.
Why is my number less than those affected? Weird
Also, how do you find your build date?
rob76 is offline
Old 04-13-2008, 11:04 PM   #185 (permalink)
'08 Civic Si
That should not affect your transmission in any way. If they try saying otherwise ask them to tell you how it could.
rob76 is offline
Old 04-13-2008, 11:10 PM   #186 (permalink)
Opticon's Avatar
myspace.com/opticon1
i pick up my 08 si 2 door next week, i dont know the vin number but it was built in feb 08, u think im alright?
Opticon is online now
Old 04-13-2008, 11:15 PM   #187 (permalink)
'08 Civic Si
How do you know when it was built?
rob76 is offline
Old 04-13-2008, 11:20 PM   #188 (permalink)
Opticon's Avatar
the tag in the door jam
Old 04-13-2008, 11:41 PM   #189 (permalink)
'08 Civic Si
SAY WHAAAAAAAT? I just looked there.
rob76 is offline
Old 04-13-2008, 11:50 PM   #190 (permalink)
'08 Civic Si
Ok had a closer look
Mine was built October 2007.
My Vin is 8H200379
When were the 8H7xxxxx vin's produced?
rob76 is offline
Old 04-13-2008, 11:58 PM   #191 (permalink)
dragonzsoul's Avatar
Brandon
LOL i wanna see what they try to pull out of their a$$
dragonzsoul is offline
Old 04-14-2008, 12:24 AM   #192 (permalink)
Si Speed 317's Avatar
Dan
Perfect!
Si Speed 317 is offline
Old 04-14-2008, 12:27 AM   #193 (permalink)
jackolee's Avatar
yay im an 07 so i have to get it fix hahaha
but idk if i wanna. i can feel when mine will grind cause i can feel it not wanting to go in properly....
and some of you guys say you can feel it being notchy, i dont want that....... what does that even mean?
jackolee is offline
Old 04-14-2008, 12:27 AM   #194 (permalink)
michinsi's Avatar
Tom
Got it! I'll call up the dealer tomorrow and set up my appointment.
michinsi is offline
Old 04-14-2008, 12:30 AM   #195 (permalink)
'08 Civic Si
It means iy doesn't just go in super smooth. You might hit a little bump or two on the way in, but it goes in nonetheless.
rob76 is offline
Old 04-14-2008, 12:33 AM   #196 (permalink)
jackolee's Avatar
do you have to keep pushing for it to go in??
or is it just like you feel like its rubbing against something but it still goes in perfectly and doesnt grind?
cause if itsthe first one that just sounds like what i have right now, and if i release the clutch when im feeling that it grinds on me
jackolee is offline
Old 04-14-2008, 12:34 AM   #197 (permalink)
sirgatti's Avatar
It's kind of hard to explain. It's like you feel it engage half way, push more because you aren't sure if it's in or not, and then it goes in the other half. This is normally followed by large amounts of swearing and/or gritting of the teeth for the next few seconds.
sirgatti is offline
Old 04-14-2008, 12:36 AM   #198 (permalink)
'08 Civic Si
do you have to keep pushing it in?
cause that just sounds like what i have right now, and if i release the clutch when im feeling that it grinds on me
You have to make sure it's all the way in before letting your clutch out. If it won't actually go in or you have to try more than once then you have issues.
Almost every car I've had has had some notchiness. I had a '91 jetta that was really notchy yet my VW mechanic said it was totally perfect.
rob76 is offline
Old 04-14-2008, 12:36 AM   #199 (permalink)
jackolee's Avatar
and if your not paying attention and you feel i goes in half way but not all the way, and then release the clutch it grinds right?
jackolee is offline
Old 04-14-2008, 12:38 AM   #200 (permalink)
ocspray's Avatar
Wrong. It's not a recall. Unless Honda can prove that the mod caused a problem, it shouldn't be a factor.
ocspray is offline
LinkBack to this Thread: http://www.8thcivic.com/forums/mechanical-problems-technical-chat/89638-honda-tsb-08-020-april-12-2008-3rd-gear.html
