Old 04-10-2008, 11:57 AM   #1 (permalink)
O6 Si's Avatar
Luisē
Engine Spudder! HELP please!!
ok for the last month or so at idle my car is fine then fairly often while ideling the rpms drop drasticly and the car will almost stall it dosent stall but comes close. Following the spudder the rpms will raise to maybe 1.5 2k then return to the natrual idle. Any ideas anyone. All input is welcome. Thank you in advance
Steps i have taken in attempt to fix
1. Fuel system cleaning
2. Cleaned Intake manifold
3. Cleaned throttle bottle
4. Ran DIGNOSTIC says my car running rich (odd)
I have CAI, test pipe, and exhuast if these have any bearing on this issue.
I HAVE DISCOVERD THE PROBLEM AND IT IS IM AN IDIOT WHILE DOING SOME WORK TO MY EXHUAST (ADDING HANGERS) I NOTICED MY INTAKE FILTER WAS COMPLETLY OFF THE TUBEING!!!!!!!! I PUT IT BACK ON TIGHT AND RESET THE ECU STARTED HER UP SHE RAN PERFECTLY
O6 Si is offline   Reply With Quote
Old 04-10-2008, 02:07 PM   #2 (permalink)
O6 Si's Avatar
Luisē
NObody has nothing come on please ive asked friends that r techs at honda and own si's they suggested the intake manifold cleaning and even gave me the product honda uses to clean it. The cleaner seemed to work for a lil but the problem continues u please some one any ideas?
Old 04-10-2008, 02:45 PM   #3 (permalink)
O6 Si's Avatar
Luisē
Lunch break BUMP!
Old 04-10-2008, 02:48 PM   #4 (permalink)
SoCal07Si's Avatar
Just call me Daddy
U have the AEM CAI? Cuz its known to do that.
SoCal07Si is offline   Reply With Quote
Old 04-10-2008, 03:00 PM   #5 (permalink)
O6 Si's Avatar
Luisē
yup aem cai but i had it since like 5k miles and never did it till like maybe 50k
Old 04-10-2008, 03:03 PM   #6 (permalink)
SoCal07Si's Avatar
Just call me Daddy
Yeah, I dont know why it took so long, but I'm pretty sure thats the reason. I knew right away that you had the AEM though.
Old 04-10-2008, 03:04 PM   #7 (permalink)
korey@teamhonda's Avatar
korey scavona
does it do this everytime or just every once in a while?
korey@teamhonda is offline   Reply With Quote
Old 04-10-2008, 03:04 PM   #8 (permalink)
SoCal07Si's Avatar
Just call me Daddy
its sporadic, i bet
Old 04-10-2008, 03:08 PM   #9 (permalink)
korey scavona
if it was every time i would say it is a idle control censor, my old prelude would do it when i was at a stop it would rev from 1k- 4k poeple would look at me stupid like i was always wanting to race.
Old 04-10-2008, 03:10 PM   #10 (permalink)
SoCal07Si's Avatar
Just call me Daddy
I bet cops loved that! I had a faulty horn switch on my camaro. When it got loose it would honk my horn throughout every left turn.
Old 04-10-2008, 03:14 PM   #11 (permalink)
korey scavona
that is awesome.....you should of just started waiving to everyone around you when that happened...lol
Old 04-10-2008, 03:23 PM   #12 (permalink)
07sedan_man's Avatar
Travis
the same thing happened to my old rsx-s and i had an aem v2 intake(with a evo2 and dcrh) on it ... i tried a couple of different things but someone said that i might have done some internal damage to the engine ... cuz my revs would drop really bad like it was gonna stall and it was runnin really rich too .. you could smell it ... have you been drivin it hard or bouncin off the rev limiter?
07sedan_man is offline   Reply With Quote
Old 04-10-2008, 03:28 PM   #13 (permalink)
O6 Si's Avatar
Luisē
i drive semi hard i v-tec daily but i dont push to 8.2 unless racing an rarely even then do i even hit the limiter i have it timed well i do have the cat eliminated and it does this id say 95% of the time when i come to a stop not constantly but it will sit there for 10-15 secs then happen then 30 secs with nothing or sum times every 7-10 seconds never actually stalls
Old 04-10-2008, 03:32 PM   #14 (permalink)
Travis
sounds like the same problem that i had ... i traded for my Si
Old 04-10-2008, 03:39 PM   #15 (permalink)
O6 Si's Avatar
Luisē
did u ever actually figure the problem out or u just assumed that was correct dignosis and traded it for the same car with a honda logo? J/K i like si better
Old 04-10-2008, 03:40 PM   #16 (permalink)
Kill Your Self Krew
Zeuceone's Avatar
Put you stock intake back on before you cause any damage.
Originally Posted by Mikey6p View Post
Cock sauce is good too.
http://killyourself1.myminicity.com/ind build my city.
Old 04-10-2008, 03:45 PM   #17 (permalink)
Travis
nope never figured it out but i did go into the dealership after i got the si and they had the hood up workin on it ... i was bout to trade it anyways, i needed a 4 dr
Old 04-10-2008, 08:42 PM   #18 (permalink)
O6 Si's Avatar
Luisē
bump for assistance
Old 04-10-2008, 08:43 PM   #19 (permalink)
WHOcaREs05050
Whocares05050's Avatar
The a/c kicking on causeing the idle to jump? idk.
Whocares05050 is offline   Reply With Quote
Old 04-10-2008, 08:49 PM   #20 (permalink)
O6 Si's Avatar
Luisē
i almost never use ac and no i know wat that is thats just the engine compinsating for the compressor robing power thats not it its way more drastic of a jump
new engine El_mahone Bolt-Ons And All-Motor 19 12-27-2007 09:01 AM
engine lag...please help! RiceEater Mechanical Problems & Technical Chat 5 07-05-2007 11:57 PM
Difference between a 07 Civic Si engine made in US and an Si Engine made in Japan jjloresco Civic SI 17 05-04-2007 03:47 PM
engine name? blueVNdragon Civic Coupe And Sedan 2 04-01-2006 11:27 AM
Stuff in Engine Tripz Mechanical Problems & Technical Chat 6 02-07-2006 02:02 AM
