Old 04-17-2008, 12:31 AM   #21 (permalink)
is b0osted!
Civicn33b's Avatar
Josh
seriously guys thanks for the help, i havent got a chance to check grounds, but i did notice when i flash my lights also the OEM rpm gauges and speed dim themselves and when i let off of the "brights" they return brighter again... dunno if its related or not, but im about pissed off. I have a damaged connector from the OEM foglights I installed when I first got the car but i butt spliced it and plugged it back in and im still having the same problem... my dad is an electrician and said it sounds like im losing contant somewhere.
please excuse me for not really understanding the electrical part but what does this mean and what could it be? would this also explain the loss in memory?
He also said it may be a fuse aswell like you guys have suggested
"oh no he dit'en"
Civicn33b is offline
Old 04-17-2008, 07:54 AM   #22 (permalink)
volvo9's Avatar
Andrew
Did you mean constant? That would mean the constant power I was talking about in my previous post. That's the constant 12v power that maintains memory when the car is off and also powers the radio and lots of other things in the car.
Have you checked the fuses yet? If so and they are all good I'd remove EVERYTHING electrical that you added (even if you think it's unrelated) and see if the problem goes away. If not then bring it to Honda. If they find something under warranty, then cool. If they find that it was your fault then you will have to pay.
Sounds like you've got a lot of wierd problems. Did you get to check out the power and ground wires I mentioned in my last post? They are a great starting point to get an idea of what's going on.
volvo9 is offline
Old 04-19-2008, 01:10 PM   #23 (permalink)
is b0osted!
Civicn33b's Avatar
Josh
Originally Posted by ryanmcm83 View Post
any loose/damaged wires or connectors along where you routed your gauge wires? If it is still not working after the gauges were disconnected that is my guess. If you've ever owned a lot of pairs of headphones you know that sometimes the wires come out of the connector ends or just enough so that it takes jiggling to get them to get a signal. This scenario is less likely with a car but the combination of symptons suggests it.
Volvo9 also suggested a fuse that might be blown that protects the memory backup power. I don't have the owners manual in front of me with the fuse diagram, but it makes a lot of sense granted that the components that aren't working usually work with the ignition switch open. The only thing it doesn't explain is why you sometimes get power with the ignition on and sometimes not. Again, more likely the main feed line for your interior electronics got messed up somehow.
Your problem doesn't sound like a grounding issue so I wouldn't worry about that. What you've done is nothing out of the ordinary.
Hope that helps. GL HF diagnosing electrical problems are great!
i officially suck at reading the fuse diagram... any clue as to which fuses they would be?
"oh no he dit'en"
Old 04-19-2008, 06:01 PM   #24 (permalink)
ryanmcm83's Avatar
Ryan
That sounds like a grounding issue to me. I wouldn't try fuses until you rule out grounding for sure. If it were fuses you would have components not working at all, but it sounds like your problems are intermittent.
To get a better ground: make a ground wire (preferribly a big wire, like 16 guage) with grounding strap connectors on both sides. connect one end to between the screw and nut on your grounding connector on the battery. Connect the other end to a hole somewhere on your car chassis.
It's not surprising you are having probs with sooo many electrical gadgets you got in your ride right now.
Try that and lemme know yea or nay so I can look up some fuses for ya!
ryanmcm83 is offline
Old 04-20-2008, 03:49 PM   #25 (permalink)
is b0osted!
Civicn33b's Avatar
Josh
awsome will do bro, but im still not understanding why Id be having a grounding issue on the Nav (it came with the came and ive never fooled with it), or the door locks, or the OBDII port? The only thing I have attempted to ground were the gauges which no have power going through the fuse and is grounded well to the battery tie down nut (and the gauges work perfectly) its this other stuff thats goofing up, stuff ive never messed with.
We installed my fog lights months ago and they worked fine fo a while and then like a week later the stopped. I was diagnosing the issue and accidently snipped one of the wires in half that pinned into the harness under the dash. For the longest I just had that bare wire just chillin' so when this started happening I figured all of the excess wire from the gauges install was pushing that bare wire into something and grounding out.
Last week we fixed that bare wire and spliced the pin connector back together with a butt splice and im still having the electrical issues. I dont have a clue what ground would be bad.
Gosh I hate my life, and my car right now!
"oh no he dit'en"
Old 04-20-2008, 06:43 PM   #26 (permalink)
ryanmcm83's Avatar
Ryan
I took a look at the fuse diagram and nothing stands out as anything I'd recommend checking.
#35 in the interior box is ACC Radio, but I don't have Nav and am not sure if the fuse layout is any different.
Your next best bet if you want more things to try is to keep the car running and jiggle wires behind your fuse box. Also try the ones behind the obdII port. If your Nav and power windows start working, then you know which one is the culprit.
I'm not sure about the grounding being an issue now, sounds like nothing has been modified enough to mess things up.
The only thing I can think of now is that a critical wire going into the interior and controlling the interior electronics got separated and is making a bad connection.
I don't have the service manual with me cuz I left it at work
I'm curious about this problem and will take a look when I am at work tomorrow.
Sorry I can't help more. I've been jimmy rigging my shifter cable back together all weekend lol. It is very important to properly seat metal shifter cable bushings in the ring else you end up breaking the cable over time. I think I got it fixed, but took some mad tool buying and trying to practice butt welding some 1/8" steel rods together (which is damn near impossible with an arc welder). Ended up using a bored out compression connector and a heavy duty crimper to secure the broken ends together. ugh!
GL mang!
Old 04-21-2008, 07:02 PM   #27 (permalink)
remz857's Avatar
Jim
thats what you get for buying AEM
remz857 is offline
Old 04-25-2008, 01:27 PM   #28 (permalink)
nelsonr31's Avatar
Who's this guy comin in about AEM, have any pics of your car yet bud? ^
nelsonr31 is online now
Old 04-25-2008, 02:20 PM   #29 (permalink)
volvo9's Avatar
Andrew
He's a tool, and why is he not banned yet? Look at all the threads he started 3/4 of them have gotten locked.
volvo9 is offline
Old 05-04-2008, 02:55 PM   #30 (permalink)
is b0osted!
Civicn33b's Avatar
Josh
awsome guys thanks... i havent gotten a chance to jiggle the wires or check those fuses yet, but im hoping someone can narrow it down now due to the most recent development ive noticed...
the locks will only lock and unlock (powered) when the key is either in the II position on fully cranked, same with the headlights and interior lights... so it seems im not getting any kind of accessory power unless the key is in those two positions...
hopefully some1 can finally sort out this mess, ryan and volvo thankyou sooo much for your help thus far.
Josh
"oh no he dit'en"
Old 05-04-2008, 11:35 PM   #31 (permalink)
is b0osted!
Civicn33b's Avatar
Josh
bump for answers
"oh no he dit'en"
Old 05-05-2008, 09:02 AM   #32 (permalink)
volvo9's Avatar
Andrew
Still didn't tell me if you checked all your fuses yet. Your symptoms are really pointing towards a blown fuse.
volvo9 is offline
Old 05-05-2008, 10:56 AM   #33 (permalink)
ryanmcm83's Avatar
Ryan
ditto, sounds like the likely culprit now with them not working without the key switch engaged.
Old 05-05-2008, 01:19 PM   #34 (permalink)
is b0osted!
Civicn33b's Avatar
Josh
then again why would they come on sometimes though?! ryan said fuse #35 any other suggestions or time to pull all the interior fuses?!
"oh no he dit'en"
Old 05-05-2008, 04:26 PM   #35 (permalink)
ryanmcm83's Avatar
Ryan
jiggle wires... lol.. sounds like it's time to spend a few hours messing around with both wires first then fuses. You've got a tough problem for sure.
Odd VIN Number? menotakoala Civic SI 9 04-04-2008 09:46 PM
An odd request, please. si_civic Mechanical Problems & Technical Chat 12 12-24-2006 08:25 PM
Odd request phantom-civic Water Cooler 16 08-29-2006 04:19 PM
really really odd question si_civic Civic SI 12 07-22-2006 01:36 AM
An odd oil question... khunthun Civic SI 4 05-28-2006 12:11 AM
