Old 03-29-2008, 04:08 PM   #21 (permalink)
tac 1's Avatar
Originally Posted by firstsi View Post
no i love mine
wouldnt trade it for the world
what kind of intake do you have?
tac 1 is offline   Reply With Quote
Old 03-29-2008, 04:09 PM   #22 (permalink)
firstsi's Avatar
had a fujita sri
now im running a custom icebox from the stock box
firstsi is offline   Reply With Quote
Old 03-29-2008, 04:15 PM   #23 (permalink)
Si Speed 317's Avatar
Dan
Well it looks on correctly. I know you said you checked all vacuum lines, but check again. If you think it's all good, take certain lines off and put them back on again, making them snug. After you're 100% sure (only after checking, not just looking) then start your Si and see what's up. Normally, the idle wanders like that when there's a 'leak' in the intake at some point. Check as far down the piping as possible, make sure there's no hole/opening in it.
Si Speed 317 is offline   Reply With Quote
Old 03-29-2008, 04:21 PM   #24 (permalink)
I check all my clamps, vacume lines, bolts and reset my ecu. But let me go over it again to make sure . TNX!
if u still can't find the leak... go to ur local auto parts store and buy some brake cleaner... with your engine running spray the brake cleaner on all the gaskets/bolts/hoses/etc... basically anywhere u think the air might seep through... if it has a leak the engine will drop idle for a sec...
Old 03-29-2008, 04:27 PM   #25 (permalink)
tac 1's Avatar
I'll do that. but is it also possible to have that kind of behavior if i broke my sensors?
Old 03-29-2008, 04:34 PM   #26 (permalink)
tac 1's Avatar
Noobie question though, is it 100% safe if the brake cleaner gets in to my combustion chamber?
Old 03-29-2008, 04:36 PM   #27 (permalink)
it's safe... it will shut the engine down if u spray too much... but it won't damage anything... w.e is not burned up will evaporate...
that's the easiest way to find an intake leak...
Old 03-29-2008, 04:42 PM   #28 (permalink)
tac 1's Avatar
I'll try that tomorrow. I have to go work. Thanx!!
Old 03-29-2008, 06:02 PM   #29 (permalink)
You're doing it wrong!!
Gonzo's Avatar
If your sensors are broken you should be throwing a CEL.
Gonzo is offline   Reply With Quote
Old 03-29-2008, 06:06 PM   #30 (permalink)
WHOcaREs05050
Whocares05050's Avatar
are you sure that the whole under the spacer was pluged? If you left it open, it could still be drawing in unmettered air inside the intake manifold causing the " rev hang "
Originally Posted by KingMarineM16a4 View Post
I'm the homosexual guy that got my sister pregnant.
Whocares05050 is offline   Reply With Quote
Old 03-29-2008, 06:10 PM   #31 (permalink)
Dan
Yes but you would get a Check Engine Light for that.
I just looked at my engine bay, did you forget to install the Nitrous plug that is opposite of the P2R logo (it is on the driver-facing side of the spacer) or maybe it fell out?
Edit: Just saw Gonzo and WhoCares said the same thing. Didn't read the above posts.
Old 03-30-2008, 12:17 AM   #32 (permalink)
tac 1's Avatar
I did for a second then I reset the ecu and it never came back.
Old 03-30-2008, 12:25 AM   #33 (permalink)
tac 1's Avatar
all 4 bolts on the Tb is sitting perfecltly
Old 03-30-2008, 12:33 AM   #34 (permalink)
BubzSI's Avatar
Travis
No the hole for the Nitrous..
On the side of the Spacer facing your engine, theres a hole thats threaded which should have came w/ a plug.
Did you put that in?!?!
BubzSI is offline   Reply With Quote
Old 03-30-2008, 12:38 AM   #35 (permalink)
tac 1's Avatar
I did get a cel but i reset the ecu and drive the car long enough and it never came back. So far, it has'nt.
Yes i did install the plug.
Old 03-30-2008, 12:41 AM   #36 (permalink)
tac 1's Avatar
wrong quote. my bad. i did that though
Old 03-30-2008, 12:43 AM   #37 (permalink)
BubzSI's Avatar
Travis
ok good.. lol
Old 03-30-2008, 12:57 AM   #38 (permalink)
Gonzo's Avatar
You're still getting the rev hang?
Maybe try taking it apart and putting it back together?
I removed my TBS and just left one gasket in since the stock papery one is long since gone. It was hard to tell if it was different because I also swapped rear swaybars so I was kinda bombarded by different feelings in the car.
Throttle reponse could have possibly been a tad better but really hard to tell.
Sound has changed, dunno what that is due to. There is pretty evident hiss at mid throttle, sub 4k.
One thing that does have me concerned is the hole on the gasket does not line up with the port on the manifold that well. If I align it at the top it extends past the bottom by a noticeable margin. Makes me wonder about turbulence. Thought I'd mostly be concerned about the same effect on the manifold gasket since it is soo close to the intake ports and injectors.
Old 03-30-2008, 03:55 PM   #39 (permalink)
Dan
^ IIRC, turbulence helps to a certain extent for fuel efficiency and not performance (turbonator sh!t) but yea you're right the gasket seemed to not line up when I installed mine, but I gave it a little fiddling and it sat perfect.
OP, See the hole on the black spacer facing down in the middle on the flat part? There should be a plug that came with that. Check that the plug is in there now, incase it fell out.
Old 03-30-2008, 03:59 PM   #40 (permalink)
Gonzo's Avatar
Yeah, mine cannot be aligned, the shape and size of the gasket is off. I may have to order a new one.
As far as turbulence helping fuel efficiency, I cannot believe that would be the case here. From the TB on it is smooth sailing.
I don't know how I feel about the manifold gasket if it is off. I really don't want to tear the front end apart again, but if there is a discrepancy in fit then it might be for the best.
I don't know what P2R's stance on this would be.
NST Pullies or P2R TBS, TBGs & IMG ?? Phalanx Bolt-Ons And All-Motor 9 01-24-2008 05:45 PM
P2r Tbs c130turboprop Bolt-Ons And All-Motor 15 12-25-2007 01:54 AM
Is the P2R TBS and gasket worth it???? BEN08Si Bolt-Ons And All-Motor 13 11-13-2007 07:06 AM
A few [noobish] P2R TBS questions ObTsu Bolt-Ons And All-Motor 11 09-26-2007 11:06 AM
Fujita SRI and P2R TBS BiggJ12 Bolt-Ons And All-Motor 12 09-02-2007 10:43 PM
