Old 03-27-2008, 03:49 AM   #1 (permalink)
Cody
Too Much Oil???? :(
Yesterday i pulled the dip stick on my 2 week old 08 civic SI and my oil was below the low mark on the dipstick. So i put 2 quartz of 5W-30 in and measured again and realized i had put to much in. I took it to my Honda Dealership and had the Service Manager look at it and he said i am maybe a quarter of a quart to a half quart over the full mark and that it wasn't really that big of a deal and that some of the oil would burn and that it wont cause any harm to my engine. IS THIS TRUE????
CO The Producer is offline   Reply With Quote
Old 03-27-2008, 03:51 AM   #2 (permalink)
Kill Your Self Krew
Zeuceone's Avatar
new engines do burn oil. should be ok.
Originally Posted by Mikey6p View Post
Cock sauce is good too.
http://killyourself1.myminicity.com/ind build my city.
Zeuceone is online now   Reply With Quote
Old 03-27-2008, 03:56 AM   #3 (permalink)
Cody
ok cool because i thought i had heard that having too much oil can mess up the compression of your engine.
Old 03-27-2008, 04:39 AM   #4 (permalink)
ao47's Avatar
Mark
I believe that is also true too, but then again your engine is still new so it should be fine. There's just soo much variables to everything.
ao47 is offline   Reply With Quote
Old 03-27-2008, 04:45 AM   #5 (permalink)
SoCal07Si's Avatar
Just call me Daddy
1/4 to 1/2 over is nothin to worry about
SoCal07Si is offline   Reply With Quote
Old 05-02-2008, 12:14 AM   #6 (permalink)
hiphopaddict's Avatar
Kevin Williams
I have always been told that overfilling is just as bad as underfilling. Unfortunatley honda manages to overfill mine everytime they change it. I'm not sure how they do it, but it's always at least a eighth of an inch above the full mark. I made them change it again one time. Lately I've just given up. My warranty is almost up, so I will begin changing it myself.
hiphopaddict is offline   Reply With Quote
Old 05-02-2008, 12:19 AM   #7 (permalink)
Bottle Fed!
WhiteSicivic06's Avatar
Ryan
Our cars take 4.5 quarts, how in the hell can you get this wrong? We have dipsticks and theres even markings on the oil quart bottles!! this simply amazes me.
N2O TW FTW!
216 N/A 250.57 N2O
Mid Atlantic Member# 17
WhiteSicivic06 is offline   Reply With Quote
Old 05-02-2008, 03:19 AM   #8 (permalink)
'08 Civic Si
Being an 1/8 of an inch over the full mark is not a problem. Having half an inch above is getting dangerous, you can wreck things.
rob76 is offline   Reply With Quote
Old 05-02-2008, 09:28 AM   #9 (permalink)
Kidekat's Avatar
A half quart over is actually too much. A full quart over can cause seals to blow out, and cause oil to foam up in the pan by the crank resulting in starvation.
Just unscrew the drain plug a bit ans let teh oil drip out slowly to the correct level.
Kidekat is offline   Reply With Quote
Old 05-02-2008, 11:32 AM   #10 (permalink)
Duce2k's Avatar
You're gonna probably burn some of that oil up anyway so don't worry about it, most likely you're still breaking it in and you will burn more oil during the break in period. I've changed my oil 3 times since I had my car, and I've added at least a quart every 5k miles
Old 05-02-2008, 01:20 PM   #11 (permalink)
Honda_Si's Avatar
D Rock
Correct your mistake.
Honda_Si is offline   Reply With Quote
Old 05-02-2008, 02:20 PM   #12 (permalink)
mrdimsum's Avatar
kelly
by having too much, these following problems can happen
the oil will foam/bubble up and will not allow the oil to do what its suppose to
it is claimed that too much oil can lead to catylic damage....
mrdimsum is offline   Reply With Quote
Old 05-02-2008, 02:21 PM   #13 (permalink)
mrdimsum's Avatar
kelly
not to be an ass, but why would you put 2 quarts in and not check after the first quart?
Oil changed, but oil life won't reset!! Plz help!!!11 MurderedOut08Si Mechanical Problems & Technical Chat 4 03-21-2008 08:39 PM
Is it me or are the gear ratios too close and too high? PeterC. Civic SI 87 02-27-2008 11:13 PM
OIL LIFE 100% too long?? J.sPeciaL Mechanical Problems & Technical Chat 43 02-09-2008 11:31 AM
Engine oil, is this too dark? Gonzo Mechanical Problems & Technical Chat 20 02-04-2008 01:36 AM
lol this is too funny!! too True to! Chase Water Cooler 10 08-19-2007 03:19 PM
