alignment or tire balance
the other i felt that when i take my hands off the wheels , my car goes to the right side of the road.so i checked my tires pressure ,left is 40psi right is 36psi.my car is 6800 miles only is it possible that i need a alignment already or you think i just need to balance the tire, thanks.
Mine started doing that after my second service at 9400 miles when they rotated the tires, i thought it would go away fter awhile once the tires started to wear evenly, but its now at 12,800 and it's still goes to the right a bit, I think i'm due for an alignment, maybe you need one. won't hurt to get them balanced too
#10 (permalink) |
Well, many roads are designed so that water flows away from the center and towards the side. the road is like ( If you were to turn it 90 degrees lol.
Of course, not all roads are this way, and it shouldn't be pronounced to where you are fighting it all of the time. |
#12 (permalink) |
I have the same problem, but I took it in for an alignment at the dealership. It still pulls to the right. The alignment was out of whack, and I got the sheet that shows all of the corrections that were made to the camber, toe, etc. The wheels and tires I have on my car are from a previous car I used to own. I am guessing this pull is due to uneven tire wear.
#13 (permalink) |
You know something when you get the car from Honda. They actually give a little excess toe in on the right side to keep the car from pulling hard to the right from the road pitch. When I had an alignment check up I saw the right front was quite toed in on the sheet. Afterward it started to pull just a little to the right when the alignment was zeroed out.
| balance shaft Delete? | mfinlay04 | Bolt-Ons And All-Motor | 33 | 05-09-2008 03:47 PM |
| Cheapest tire mount/balance in San Diego North County? | civicracer32 | California South | 2 | 02-08-2008 08:31 PM |
| tire pressure, alignment problems | 07k20z3ftw | Mechanical Problems & Technical Chat | 5 | 07-23-2007 11:42 AM |
| uneven tirewear.... alignment? bad tire? or neglect :( | VdoManZ | Mechanical Problems & Technical Chat | 10 | 06-04-2007 08:11 PM |
| EX wheels off balance | tomasro | Wheel And Tire Upgrades | 2 | 03-19-2007 04:11 AM |
