Old 03-24-2008, 01:42 AM   #1 (permalink)
Coolant level?
Is the coolant supposed to be at the very top when the engine is cool or a little below? I'm talking about the actual coolant level in the radiator, not the overflow tank (which is fine and the level hasn't changed). It's an Si btw if it matters...
Anyone want to check theirs real quick?
asdf is offline   Reply With Quote
Old 03-24-2008, 10:38 AM   #2 (permalink)
Duce2k's Avatar
The last time I checked mine, last week, it was full all the way to the top
Old 03-24-2008, 10:42 AM   #3 (permalink)
krazyhusky's Avatar
Alex
^ Same too
krazyhusky is offline   Reply With Quote
Old 03-24-2008, 12:25 PM   #4 (permalink)
Ok thanks.
Old 03-24-2008, 12:28 PM   #5 (permalink)
Johnold's Avatar
John
put the coolant when it's cold, all the way to the MAX line. you should be fine. when you've been driving for a while and you get out to check your coolant level it should be about 1" above the MAX line. coolant expands. you don't really wanna fill it to the top cause it's just gonna drain off. plus that dangerous and kinda stupid IMO.
I've never looked in my radiator before. i'm sure it's fine since it's only 1 year old (Si also)
Johnold is offline   Reply With Quote
Old 03-24-2008, 12:40 PM   #6 (permalink)
Only reason checked cuz I put my stock intake back on and coolant spilt out.
Old 03-24-2008, 04:32 PM   #7 (permalink)
Johnold's Avatar
John
oh ok yeah, they always say that happens when messing the intakes. Just refill it like everyone else does. I don't think i'll ever really do any engine mods to my Si for a while. Atleast not while the warranty is still in affect.
Old 03-24-2008, 05:40 PM   #8 (permalink)
Jason
is suppose to be over the MAX line after the car has been driven? mine is just at the MAX line after driving and at the MIN line when the engine is cold.
Old 03-24-2008, 06:02 PM   #9 (permalink)
Johnold's Avatar
John
^ thats fine too. My level was a bit below the min mark (when cold) and I filled it up to the MAX line when my car was cold. this was in the morning before i drove. after about 2.5 hours out, i popped the hood and checked the level and it was at about an inch above the MAX line. thats cause it expanded. thats a safe zone. you don't wanna fill it all the way up to the top with about 1 inch from the cap (cold) and then go driving it cause it'll expand and probably pop the top off the fill tank. anyways, yeah, just keep it atleast to the MIN line when cold and you'll be fine.
Old 03-24-2008, 06:08 PM   #10 (permalink)
Ok yeah, I just got back from driving for awhile and its right about 1" above the max line on the over flow bottle.
Found a little leak too in one of the hoses.
Old 03-24-2008, 08:27 PM   #11 (permalink)
Johnold's Avatar
John
ooh, thats not good. not HORRIBLE but not good. you should just get a new hose and be done with it.
Old 04-14-2008, 09:46 PM   #12 (permalink)
RedLineSi's Avatar
Rob
Does the Si take a certain kind of coolant??
RedLineSi is offline   Reply With Quote
Old 04-14-2008, 11:36 PM   #13 (permalink)
BigT's Avatar
When the car heats up the coolant expands and the excess is forced into the overflow bottle. The max line is simply there to allow enough expansion room so that none leaks out when the car is hot. Above the max line when hot is fine. Above the max line cold is ok too, but some may leak out when the car gets hot.
However, when the car cools down the coolant is drawn back out of the overflow tank into the radiator. The radiator should stay completely full. The minimum line is more important because it insures that there is enough coolant to keep the ratiator full when the car cools.
The coolant is Honda's version of extended life coolant. Every manufacturer seems to be coming up with their own coolant. According to the manual you can use any coolant which meets the protection requirements as a "temporary replacement." If you get something (extended life) which is labeled to be mixed with any color, any brand you should be ok.
BigT is offline   Reply With Quote
Anyone have trouble reading the coolant level? spyder2244 Mechanical Problems & Technical Chat 2 11-22-2007 12:48 PM
low coolant level shutter13 Mechanical Problems & Technical Chat 14 08-26-2007 11:53 AM
Volume Level Fluctuations Southsider I.C.E., Electrical, Security, & Navigation 3 11-30-2006 12:20 AM
Question about oil level? crincon Mechanical Problems & Technical Chat 4 08-30-2006 11:26 PM
