Old 03-23-2008, 02:14 PM   #1 (permalink)
sohcegbc's Avatar
2nd gear grinding now...
so ive noticed a cuple weeks ago i wud try shift into 2nd gear around 8000 rpms...wud miss the gear every once n a while..now it grinds everytime cant get 2nd nemore...taking it back to the dealer this week.
sohcegbc is offline   Reply With Quote
Old 03-23-2008, 02:21 PM   #2 (permalink)
06si's Avatar
Kenny G
Have them put in the new Honda MTF fluid. I did it in my SI and it helped alot
06si is online now   Reply With Quote
Old 03-23-2008, 02:38 PM   #3 (permalink)
I Vtec, do you?'s Avatar
Dealer won't help you with this if they're anything like mine.
I Vtec, do you? is offline   Reply With Quote
Old 03-23-2008, 03:40 PM   #4 (permalink)
c130turboprop's Avatar
did n e one try hard when they first got their car to take it easy for the break in period??? i did and i have had not one problem with my tranny...
c130turboprop is offline   Reply With Quote
Old 03-23-2008, 03:43 PM   #5 (permalink)
Excalibur's Avatar
Jeremy
That sounds like your fault for misshifting the gears. Grinding them and whatnot. You probably messed up the synchros.. You'll be lucky if they cover that. Did you swap your tranny fluid before all this happened? Swapping the fluid helps with the smoothness of your tranny but doesn't remedy bad driving.
Excalibur is online now   Reply With Quote
Old 03-23-2008, 03:49 PM   #6 (permalink)
reaper702's Avatar
my 2nd gear syncros were bad and replaced by my dealer. it would grind the majority of the time when i shifted from 1-2 at those rpms as well and finally they went bye bye one day. after dealer replaced the syncros i have not had one single grind. obviously it is not driver error but more of a defect.
reaper702 is offline   Reply With Quote
Old 03-23-2008, 03:56 PM   #7 (permalink)
Johnold's Avatar
John
^Exactly!, I did this and really have no problems. Sometimes 3rd won't go in smoothly but it goes in. 9 times out of 10 times my car shifts smooth and quietly. took it easy for my break in period aswell.
Johnold is offline   Reply With Quote
Old 03-23-2008, 03:59 PM   #8 (permalink)
projectprelude's Avatar
Aaron
a buddy of mine got an 08 fg2 awhile ago and he doesnt have a 3rd gear problem but a second gear problem when you shift it in second fast it grinds no matter what...not a driver problem either b/c i also drove it and you have to pretty much ease it in second or itll grind
projectprelude is offline   Reply With Quote
Old 03-23-2008, 06:28 PM   #9 (permalink)
sohcegbc's Avatar
lol well i dont like its my fault..when 13,000 miles later it started to grind at high rpms..and is getting worse..not driver error at all..but will prolly take to dealer tues. on my day off i will keep yous updated.
Old 03-23-2008, 06:58 PM   #10 (permalink)
Excalibur's Avatar
Jeremy
Sounded like you said you were grinding gears.
Old 03-23-2008, 07:37 PM   #11 (permalink)
SiCivic83's Avatar
I've had problems with 2nd gear grinding from time to time. I voiced my complain to Honda about 3rd gear popping out and they replaced it with Honda MTF fluid and it hasn't popped out on me ever since. The next chance I get I will take it back to Honda to check out the synchros for 2nd gear.
SiCivic83 is offline   Reply With Quote
Old 03-23-2008, 07:41 PM   #12 (permalink)
Special Ringpop's Avatar
I've had the MTF replaced twice with new stuff and within the first month, third was popping out and second was grinding again.
Originally Posted by ImTheVoiceofGod
This was basically the "your mom" of this conversation. A statement meant to mean "I have nothing usefull to contribute as all of my resources have been exhausted. But I am not man enough to admit this so I will now resort to childish bickering."
Special Ringpop is offline   Reply With Quote
Old 03-23-2008, 08:33 PM   #13 (permalink)
sohcegbc's Avatar
k series trannys FTL
Old 04-03-2008, 03:27 AM   #14 (permalink)
drumkid8's Avatar
i so have this effin problem... and i'm extremely fed up... i dont know what to do anymore
drumkid8 is offline   Reply With Quote
Old 04-03-2008, 04:38 AM   #15 (permalink)
dragonzsoul's Avatar
Brandon
welcome to my world.. how'd you get them to replace your synchros though? i want new ones also
same issue as me.. my 3rd gear does it too..
you're lucky, the new honda MTF doesn't work well for me.. i grinded all the in 2nd and 3rd with it..
*sigh* keep b!tching to your dealer? maybe one day they'll give in. you can also call Honda NA and get a case number. i have one, and am waiting for a 3rd gear synchro replacement.. whenever honda gets around to it..
dragonzsoul is offline   Reply With Quote
Old 04-03-2008, 04:28 PM   #16 (permalink)
Good luck. Honda shut my case file the first time without ever talking to me (the bitch who I dealt with refused to call me at any other time besides the one I was in class) and the second time, the same bitch said "What do you want me to do? You can't even get your dealer to replicate this."
Old 04-03-2008, 04:29 PM   #17 (permalink)
drumkid8's Avatar
have a question... will they give me sh!t for saying that it doesn't go in at 8k? cause at 7k+ it won't go in and just grinds..
Old 04-03-2008, 04:33 PM   #18 (permalink)
Brandon
never tell your dealer how hard you drive your car.. they'll use it against you somehow, those sneaky b@stards..
just say it grinds when you shift into 2nd
Old 04-03-2008, 04:35 PM   #19 (permalink)
volvo9's Avatar
Andrew
Gears are grinding, but it's not his fault. There's a lot of people that complain of this. rev car up to 8000 accelerating in first, go for second and it immediately grinds, even with the clutch at the floor still.
Old 04-03-2008, 04:48 PM   #20 (permalink)
drumkid8's Avatar
yup! and it sucks cause i can't think of a way to tell my dealer to fix it... i know they're gonna make a mechanic drive it... and he's gonna do it at normal shift speeds so its gonna be pointless
2nd to 3rd grinding/skipping astroluc Civic SI 13 02-20-2008 01:40 AM
After getting 3rd gear fixed... 1st to 2nd grinding aki Mechanical Problems & Technical Chat 7 02-14-2008 09:05 PM
For those grinding 2nd... 2RotorMotor Mechanical Problems & Technical Chat 108 08-25-2007 03:55 PM
1st to 2nd gear grinding at high rpms pate2901 Mechanical Problems & Technical Chat 2 04-22-2007 03:19 PM
