#21 (permalink) |
I would like to get this straight... stock Si have problems with blown head gasket? It should only happen if you push the car TOO HARD, and cars that have too much PSI from Force Induction such as TURBO or Supercharger.
yes no? |
#22 (permalink) | |
Jeffery
If you have only 25K on the motor, it's still under honda factory warranty, and they should fix that **** for FREE. Don't go buying head gasket, or ARP studs until you find out honda won't replace it for free. Plus, i don't see how a header install would cause a head gasket failure, but probably better safe to remove it before taking it in to honda. No other mods? if not, you have a strong case for getting honda to replace it for free under warranty. |
#24 (permalink) |
Dan
Yep.....
I think your pushing too much PSI for the head gasket to fail, or just a BAD gasket. I know plenty of people who rev the shi* out of there's
9+ and have almost no problems. (Side note please don’t rev that high All the time unless you have a built motor or it WILL Blow) If you think it is a blown gasket take it to Honda and they can suck up the cost.
#27 (permalink) |
Jeff of QSR
Took my ride to the dealer today for a bad gasket - I was being honest when I told them that I have a header and they took my car in for fix - BUT Here's what I told the service advisor that when I'm installing the header I notice the oil from the head gasket so he took it in with no questions asked.. I asked the tech what's the cause he said it is all from the heat building up causing the gasket to weakened and plus our engine is tilted towards the firewall so most likely the oil will seep from the back..
#31 (permalink) |
my car is in the shop for a blown gasket, damn thing has been blown for over 8 weeks, im not sure how bad the damage is but i dont think its much, maybe i caught it early enough? how long does it take b4 the gasket and engine is badly damaged...?
#36 (permalink) |
Mitch [Ryan #3]
It can definitely happen to the r18. It happened to my stock d17.
Just don't bounce between 100mph and 120mph for 2.5 hours, like I did. Self-fail.
#37 (permalink) |
Jacob
i just took mine in today, i noticed some oil on my sub frame, so i took it to honda they fixed it in 2 hrs and washed and waxed my car haha all for free
and btw i have a 2007 si with 23k on it.... bone stock, the guy said the stock gasket is much weaker than the new one the put in he said it should never blow again
#40 (permalink) |
^ Read the original post.
![]() Does anyone know if the 09+ come with upgraded head gasket from the factory? I find it so strange that civic and SI both blow head gaskets, how could they start falling into Mitsubishi teritory with the K20Z3 when the A2/3 were bullet proof? Last edited by DC5; 03-29-2010 at 11:15 PM. |
| Warped Head?? | JoJo07FBPFG2 | Mechanical Problems & Technical Chat | 42 | 04-05-2008 12:52 AM |
| blown trannys n e 1? | all motor K'S | Mechanical Problems & Technical Chat | 11 | 03-13-2008 11:16 AM |
| well add another blown si to the forum | liquidr1 | Forced Induction And Nitrous | 80 | 09-22-2007 11:11 PM |
| Me vs Blown Stang | ibanez37 | Autocross & Sanctioned Drag Racing | 53 | 07-11-2007 04:14 AM |
