Old 03-20-2008, 10:49 AM   #1 (permalink)
2008 Tsb
I just found this TSB on the NHTSA website. Its for 2008 Civics, came out in Dec. 2007. I'm not sure if its model specific. I tried searching but didn't find any specifics.
The description is pretty vague:
Component : ENGINE AND ENGINE COOLING:ENGINE:GASOLINE:BELTS AND ASSOCIATED PULLEYS
Anyone know anything about this??
TSB Results : ODI - Office of Defects Investigation
if the above link doesn't work go here:
and search by year, make and model.
eg_bert is offline   Reply With Quote
Old 03-20-2008, 10:52 AM   #2 (permalink)
Leonard1818's Avatar
Leonard
second link works... if you click thru and click "get summary" you see the following:
Make / Models : Model/Build Years:
HONDA / CIVIC 2006-2008
HONDA / CIVIC HYBRID 2006
Service Bulletin Number : 120107
NHTSA Item Number : 10024034
Summary Description :
INSTALL CRANKSHAFT PULLEY CORRECTLY TO PREVENT OIL PUMP DAMAGE. *NJ
EDIT: That doesn't sound good... I'd probably be taking my civic or civic hybrid in for service before something breaks! Looks like it excludes the Si tho... lucky me!
Leonard1818 is offline   Reply With Quote
Old 03-20-2008, 11:13 AM   #3 (permalink)
Jason
^just wondering, but what makes you think it's excluding Si's?
Old 03-20-2008, 11:21 AM   #4 (permalink)
siufai's Avatar
Sammy
it is in the honda news bulletins for December 2007: Honda Service News Bulletin Archive and it says except SI
siufai is offline   Reply With Quote
Old 03-20-2008, 11:27 AM   #5 (permalink)
Jason
^hmm so this thread is a repost then huh?
Old 03-20-2008, 11:32 AM   #6 (permalink)
Ahhhhh... I see it now, that link wasn't working for me before... it does now.
Theres pictures and everything...
heres what it says:
Currently Applies To: ’06–08 Civics (except Si) and ’06–08 Civic Hybrids
When installing the crankshaft pulley, make sure that you line up the four flat sides of the pulley with the four flat
sides of the inner oil pump gear. If you don’t, and you just try to force the pulley into place, the pulley will drive the
gear right into the oil pump casing and crack it.
sorry for the repost everyone...
Thanx siufai.
Old 03-20-2008, 11:33 AM   #7 (permalink)
Leonard
Just cause it says----
I would think if it included the Si it would say something in the list like----
HONDA / CIVIC SI 2008
not sure tho!
And yes, now that I read the dates, I think this is a repost. It's pretty sad when this has been happening since 06 on the regular civic models and they still haven't gotten it right by 08.
Old 03-20-2008, 11:59 AM   #8 (permalink)
siufai's Avatar
Sammy
heres what it says:
Thanx siufai.
no problem, i was wondering the same thing a couple of weeks ago and so i looked it up
Tsb?! luiek20 Mechanical Problems & Technical Chat 1 01-23-2008 08:05 PM
Locating TSB, please help Dj_AmtraX Mechanical Problems & Technical Chat 2 11-01-2007 03:28 PM
New TSB? Si 07 Civic SI 3 09-14-2007 08:04 PM
What does this TSB mean? amirh Mechanical Problems & Technical Chat 4 04-26-2007 12:10 PM
TSB(uh-0h) striker_1818 Mechanical Problems & Technical Chat 11 01-04-2007 02:19 PM
