Old 03-20-2008, 12:30 AM   #1 (permalink)
JoJo07FBPFG2's Avatar
JoJo
Exclamation Warped Head??
So i was low on coolant... took it 2 HONDA!... so its gunna sit there for 2nite... they told me i might have a fukd up head... but hopefully nuttin big is wrong with it... any1 else here blown any heads... not it that way!! haha...???
JoJo07FBPFG2 is offline
Old 03-20-2008, 01:01 AM   #2 (permalink)
NHPB ftw
Arganon's Avatar
Gordon
lol blown head
Arganon is offline
Old 03-20-2008, 01:04 AM   #3 (permalink)
Whos The Whore NOW
07mugencivic's Avatar
Tony
Originally Posted by Arganon View Post
lol blown head
07mugencivic is online now
Old 03-20-2008, 01:04 AM   #4 (permalink)
emopains's Avatar
Marcus
^intel's vtec inside and hondata chipset inside
Eblocked
emopains is online now
Old 03-20-2008, 01:10 AM   #5 (permalink)
Michael
never heard of a blown head. probably just warped. they'll have to replace, because if they mill it, you're compression ratio will go up.
Street2uned is offline
Old 03-20-2008, 01:12 AM   #6 (permalink)
Kill Your Self Krew
Zeuceone's Avatar
Blow this.
Any reason why you were low on coolant?
is Missy a squirter?
Zeuceone is online now
Old 03-20-2008, 01:20 AM   #7 (permalink)
JoJo
well ... there going to do a tear down and see whats up! ....
Old 03-20-2008, 03:12 AM   #8 (permalink)
Kill Your Self Krew
Zeuceone's Avatar
dammm.
Old 03-20-2008, 08:21 AM   #9 (permalink)
siufai's Avatar
Sammy
I had this problem back in October with my 02 Sentra GXE. Instead of getting it fixed and putting a new engine in it, I traded it in and bought the SI.
siufai is offline
Old 03-20-2008, 08:42 AM   #10 (permalink)
NIGHTHAWKSI's Avatar
what mods are done to the car?
intake or IMG? both those require disconnecting coolant lines and you might have let too much leak out.
NIGHTHAWKSI is online now
Old 03-20-2008, 04:39 PM   #11 (permalink)
Why were you low low on coolant? Did you just drive it around knowing that you were low on coolant? Your head could be warped if it got REALLY hot, but I doubt there's any damage if it just got hot once.
rotor_powerd is offline
Old 03-20-2008, 06:59 PM   #12 (permalink)
JoJo
i got a CAI... and the car never got hot.. didnt even notice it till 2 days ago before i put on my HIDs....
Old 03-20-2008, 07:43 PM   #13 (permalink)
06rdsi's Avatar
i think i may have the same problem and i checked for leaks and left over coolant in the engine compartment i was low on coolant and when i would drive my car then park it in my garage i could smell the burnt coolant smell it may be my head too
06rdsi is offline
Old 03-20-2008, 08:13 PM   #14 (permalink)
JoJo
yeah take it 2 the stealership!!.. still no word on my whip!!...sucks being without a car...
Old 03-20-2008, 08:14 PM   #15 (permalink)
is stuck at work...
SiliconX's Avatar
Eric
Don't you guys...I dunno...CHECK this stuff?
Takes all of 5 seconds to check your coolant level. Should always check that stuff regularily.
SiliconX is offline
Old 03-20-2008, 08:27 PM   #16 (permalink)
JoJo
had the my oil changed a month ago and all fluids were ok..
Old 03-20-2008, 08:55 PM   #17 (permalink)
is stuck at work...
SiliconX's Avatar
Eric
I mean more often than a month.
I check my tire pressure, coolant level and oil level at least once a week.
SiliconX is offline
Old 03-20-2008, 09:36 PM   #18 (permalink)
Opticon's Avatar
myspace.com/opticon1
if you drained the coolant then refilled it, u have to bleed the coolant system, if you dont bleed it, u could have a air pocket somewhere in the head where the coolant runs which will cause like a hot spot and warp the head. i dont think u have a blown head gasket, car is too new for that shit. and the only other way u can warp it is if you run it extreamly low on coolant or if your coolant fan isnt working. personally i dont trust dealerships with mech stuff, i do all my own work to be sure its done right. if they tell u that u need a new head and they want to fix it, take a marker and mark a spot on the head so when u get it back if the mark is gone, then they did what they said they were gonna do and if the mark is still there then u know they are bs. :) oh and they should only charge you for 5.3 hours of labor according to real time labor guide
Opticon is offline
Old 03-21-2008, 06:07 PM   #19 (permalink)
Michael
Good info
Old 03-21-2008, 06:12 PM   #20 (permalink)
BATANG CITY JAIL's Avatar
no need to bleed.. just open the rad cap and letthe engine run till it gets hot then just keep filling the coolant..
thats what i did btw.. and no problem..
BATANG CITY JAIL is offline
Rotors Warped 07civicex20 Suspension and Brakes 2 02-16-2008 05:53 PM
Are warped rotors covered in the warranty? 94134 Suspension and Brakes 12 02-16-2008 01:06 PM
Rotor is shot... Warped? 93sidood Mechanical Problems & Technical Chat 7 06-26-2007 01:16 AM
2 of the top JDM Tuners go head to head! OH_KY07 Autocross & Sanctioned Drag Racing 13 05-08-2007 02:18 AM
Pics of head installed head units? Drywin I.C.E., Electrical, Security, & Navigation 20 11-03-2006 02:38 AM
