Old 06-04-2006, 01:38 AM   #1 (permalink)
thepman06's Avatar
Unhappy Outside Temp Guage
Has any one noticed that the outside temp guage on the dashboard is incorrect? I knew for a fact that the outside temp was in the 90's when the guage showed low 80's and it stayed there! You know that when you start to drive, the temp will sometimes change...this day it did not.
thepman06 is offline   Reply With Quote
Old 06-04-2006, 01:50 AM   #2 (permalink)
radiocontrolhead's Avatar
Danny
u can't base it on that. they arent' that accurate. dont rely on it for ur main source of temperature
Old 06-04-2006, 02:51 AM   #3 (permalink)
n00b retro whore
ethlar's Avatar
you can calibrate the temperature readout, check your manual
Old 06-04-2006, 10:25 AM   #4 (permalink)
BLU BY U's Avatar
mine works fine?
Old 06-04-2006, 10:51 AM   #5 (permalink)
CivicWithNav's Avatar
it gives me pretty acurate idea...
remember, it only takes in AIR TEMP right there where the car is. WITHOUT the sun being a factor so could be "little cooler" reading than you feel
Old 06-04-2006, 11:57 AM   #6 (permalink)
Resident Caraholic
Cybergypsy's Avatar
mine is wrong, then after driving it gives a good reading how ever use the the weather channel for weather...
I would rather be judged by 12, than carried by six!
Old 06-04-2006, 12:38 PM   #7 (permalink)
BLU BY U's Avatar
What are you talking about? My Si has a temp gauge and a 10day forecast.....you just have to program your zipcode. You guys didn't get that?
Old 06-04-2006, 02:31 PM   #8 (permalink)
eric3621's Avatar
The temp sensor is right below the front bumper and can be inaccurate while sitting still. The manual says that it is at its most accurate while at cruising speed.
eric3621 is offline   Reply With Quote
Old 06-06-2006, 03:29 AM   #9 (permalink)
thepman06's Avatar
thanks for all the replies. I will check the manual on that issue. I know that the temp will change after a bit. My Sequoia is just more accurate I guess.
Air Temp Sensor Problem. RODSCIVIC Mechanical Problems & Technical Chat 0 05-01-2006 09:54 PM
Installing Air/Fuel Guage bradvb I.C.E., Electrical, Security, & Navigation 7 04-16-2006 12:37 PM
