Old 03-12-2008, 03:07 PM   #1 (permalink)
itzwykd's Avatar
Kevin Briggs
Why is my pre-tensioner making this noise!!!
Any suggestions?
itzwykd is offline
Old 03-12-2008, 03:32 PM   #2 (permalink)
does it do that from 2-3k when revving?????? if so, that's my problem too!!!! I've been trying to figure it out but im getting a rattle and i have no idea whats causing it. i'll go check it out on my car when i get a chance and i'll post if that's my problem too. also, i just started having that problem after i would say about 27k. another thing is, it goes away when the car is warm. but sometimes it'll still be there even though its fully warmed up.
rcracin13 is offline
Old 03-12-2008, 03:47 PM   #3 (permalink)
itzwykd's Avatar
Kevin Briggs
Only in 1st and reverse for about a sec then it goes away. If I give the car a good amount of gas (1.5k-2k) it does not do it at all.
itzwykd is offline
Old 03-12-2008, 03:50 PM   #4 (permalink)
Jeremy
hmmm damn thats weird, did you check the tightness of the bolts
jeremy0203 is offline
Old 03-12-2008, 03:56 PM   #5 (permalink)
itzwykd's Avatar
Kevin Briggs
everything is tight and rechecked.
itzwykd is offline
Old 03-12-2008, 03:58 PM   #6 (permalink)
i guess thats not my problem then. back to the drawing board for me. btw, i have no idea what your problem could be. sorry, hope you figure it out.
Old 03-12-2008, 03:59 PM   #7 (permalink)
Jeremy
seems like the pulley or tensioner has some play in a direction it shouldnt which is causing it to move and make that noise. did you take the belt off when you checked the torque on the bolts?
Old 03-12-2008, 04:20 PM   #8 (permalink)
itzwykd's Avatar
Kevin Briggs
yea i will probably check again and put more thread lock on it. everything was rock solid and I can't even move the tensioner with my own hands. I have to use a wrench so i know it's tight.
itzwykd is offline
Old 03-12-2008, 04:46 PM   #9 (permalink)
liquidr1's Avatar
Dustin
Did you adjust the little black hex stud with the lock nut on top of the pully bracket. In the directions it tells yo to adjust it to a certain spot the have the correct tension.
If you tighten it, it will pull on the belt and make your tensioner pulley move out more allowing more space between the two parts of the belt so they wont rub like that.
It may have worked its way loose over time.
liquidr1 is offline
Old 03-12-2008, 04:52 PM   #10 (permalink)
liquidr1's Avatar
Dustin
Yea, i just went out an looked at mine. I have way more of a gap between the two spots on the belt.
Just tighten the black adjuster screw on top and it will pull up on the belt and pull the tensioner pully out more.
(you'll have to loosen your 2 pulley bolts before you can adjust it)
liquidr1 is offline
Old 03-12-2008, 07:21 PM   #11 (permalink)
hybridspl's Avatar
Steven Millar
If that is an R18, get it checked. I work @ a Honda dealer, and there are a bunch that have had the tensioner bolt break off, causing the water pump pulley to cut into the waterpump!
hybridspl is offline
Old 03-12-2008, 07:37 PM   #12 (permalink)
Jeremy
here is a pic of mine, cant really tell if i have more clearance as liquid says his does compared to yours
Old 03-12-2008, 07:38 PM   #13 (permalink)
Jeremy
your top pulley from what it looks like to me does seem to be a hella lot closer to that bolt head compared to mine. could just be the angle tho maybe
Old 03-12-2008, 08:11 PM   #14 (permalink)
radiocontrolhead's Avatar
Danny
When you install aftermarket things, who knows! Things like this come w/ the package when you mess around with a car.
radiocontrolhead is offline
Old 03-12-2008, 08:26 PM   #15 (permalink)
liquidr1's Avatar
Dustin
Sorry bro, this is not an r18. No superchargers for the r18.
its an Si with the Comptech Supercharger. His question is reguarding the pulley setup on his kit causing his belt to rub.
Silly honda techs. J/K
liquidr1 is offline
Old 03-12-2008, 08:33 PM   #16 (permalink)
itzwykd's Avatar
Kevin Briggs
You hit it right on the head. I put about five turns on the adjusting screw and no more rattle. I do not know what happen to make it come loose. the sound did not get worse over time or anything. one day it was fine the next "rattling". Thanks bro. I'm happy again.
itzwykd is offline
Old 03-12-2008, 08:36 PM   #17 (permalink)
liquidr1's Avatar
Dustin
Look where i circled. There is a little notch on your tensioner. When you adjust your black adjusting screw on the pulley bracket, this notch should be right in the center or a little more to the right. Check that. If the notch on the tensioner is to far to the left the you need to adjust it more.
by making it tighter it will put more tension on the belt and pull the tensioner pully out more.
Hope this helps.
liquidr1 is offline
Old 03-12-2008, 08:37 PM   #18 (permalink)
Jeremy
hey liquid does mine look like yours? JC
Old 03-12-2008, 08:38 PM   #19 (permalink)
liquidr1's Avatar
Dustin
lol you beat me to it. Glad i could help out.
liquidr1 is offline
Old 03-12-2008, 08:38 PM   #20 (permalink)
liquidr1's Avatar
Dustin
Yes
liquidr1 is offline
mechanical noise ? yeppi Mechanical Problems & Technical Chat 8 05-31-2007 12:55 PM
Question: Lowering and noise? 06NaviEX Suspension and Brakes 3 04-29-2007 08:17 PM
06-07 (2D & 4D) Civic & Civic Si Rattle or Ticking Noise ProspeedCTR Mechanical Problems & Technical Chat 6 03-21-2007 10:12 PM
Strut noise from lowering... Biggeo Mechanical Problems & Technical Chat 3 11-03-2006 10:23 AM
EX Coupe front suspension noise Leonardo629 Mechanical Problems & Technical Chat 4 12-17-2005 05:35 PM
