The problem with these cars is that the rear tires feather very easily, I went 20,000 miles without rotating the tires and had to replace the rear tires (they were feathered beyond use) -- I'm use to having older cars and never rotated tires, now I rotate them every 4,000 miles.
It doesn't matter how soon you rotate the tires as long as it's under 8,000 miles and consistent (every 5,000 miles for instance). If you rotate them at 4,000 one time and then wait 7,000 the next, you'll begin to get uneven tire wear. So if you start to rotate them every oil change make sure you change the oil at consistent intervals (i.e. every 5,000 miles) |
#12 (permalink) |
Location: Seeing the beauty of the world in a drop of morning dew
I am the Juggernaut!!!
Non-directional-
Front to back straight back but back to front criss-cross just like it says to do on page 248 of your manual. |
#14 (permalink) |
Jason
i thought they were supposed to be rotated every 10k miles? and compared to most people here, i must drive REALLY slow. cuz the tread on my tires barely show any wear and i have 15k miles on my 07 Si.
#18 (permalink) | |
55 in a 55 on highway 50 in a 35 on the off ramp. I have that negative rear camber too. I'm getting new A/S tires (Pilot Exalto A/S) so i have better traction in the snow. For those, i'm going to rotate every oil change.... for more even wear. I wont beable to crisscross though. |
| Tires, Camber, Caster, Toe!!! | Highrev1 | Suspension and Brakes | 28 | 05-29-2011 01:17 PM |
| *8thCivic Tire Help 101* | CrackThatTec45 | Wheel And Tire Upgrades | 60 | 04-05-2011 11:15 PM |
| Tire pressure check method?? | MADDOGSI | Mechanical Problems & Technical Chat | 25 | 02-02-2009 05:13 PM |
| Tire Rotation? | etcthorne | Mechanical Problems & Technical Chat | 4 | 01-04-2008 10:14 AM |
| Maintenance Minder & Tire Rotation | kish-81 | Mechanical Problems & Technical Chat | 14 | 10-21-2006 12:54 PM |
