Old 03-06-2008, 07:43 PM   #1 (permalink)
grinding noise under hard braking?
today i heard once again for the 4-5 time a grinding noise when i was braking hard...a school bus came around a bend and guy in front slowed down quick road was pretty dry but had a few puddles....might have slipped a little but under the braking it definitely was grinding...i applied the clutch before breaking and i think i did every time i heard it...i am new to manual tranny is it the clutch being applied thats causing a grinding
devilman2075 is offline   Reply With Quote
Old 03-06-2008, 07:47 PM   #2 (permalink)
odalV's Avatar
V.D.
u either hit a lil pothole or its just the abs. when u floor the peddle it grains like that. if its everytime u got problems my door panels make noise when i drive or listen 2 music. idk how 2 fix it i did everything i could. they look loose. does urs?
odalV is offline   Reply With Quote
Old 03-06-2008, 07:48 PM   #3 (permalink)
Dar-Dar's Avatar
Darwin
i dont hear grinding noise but i can feel it grinding with my feet. it happens to my car when i slow down (from 75mph) to an exit in the highway.
Dar-Dar is offline   Reply With Quote
Old 03-06-2008, 08:08 PM   #4 (permalink)
fox
fox's Avatar
Andrew
it sounds like that is just a ABS, it kicks in fairly easy as a precaution.
if you are tapping the brake easily and you are getting this, your pads/rotors may be worn down.
fox is offline   Reply With Quote
Old 03-07-2008, 01:09 PM   #5 (permalink)
leondb's Avatar
Leon
How old is your car? Sounds like ABS to me. Are you breaking hard?
leondb is offline   Reply With Quote
Old 03-07-2008, 02:49 PM   #6 (permalink)
bokeh's Avatar
Joe Woo
Its normal.. U can replicate it by slamming on your breaks again...
bokeh is offline   Reply With Quote
Old 03-09-2008, 12:30 PM   #7 (permalink)
well im glad its normal....i get scared when i hear it...i dont hear it alot but it seems when theres a little wheel slip or the roads arent great it happens no matter what speed im going....the only thing is that it doesnt sound great it just sounds like metal on metal grinding but if its just the abs than i guess its ok, my last car didnt have abs so i gotta get used to it
Old 03-09-2008, 11:54 PM   #8 (permalink)
It's normal.. just your breaks slapping and releasing quickly... purpose of ABS is to prevent a wheel from slipping and losing traction... These civics definitely air on the side of caution; very sensetive sensors... if you have VSA, it may even do it when you don't touch the brake pedal!
Sabre is offline   Reply With Quote
Old 03-10-2008, 02:14 AM   #9 (permalink)
honda_man12's Avatar
sounds like the ABS kicking in....happens especially when breaking in the snow
honda_man12 is offline   Reply With Quote
Old 03-10-2008, 02:19 AM   #10 (permalink)
ABS to me!
FutureITR is offline   Reply With Quote
grinding hard bmcivic Mechanical Problems & Technical Chat 5 01-20-2008 11:56 PM
Question: Lowering and noise? 06NaviEX Suspension and Brakes 3 04-29-2007 09:17 PM
06-07 (2D & 4D) Civic & Civic Si Rattle or Ticking Noise ProspeedCTR Mechanical Problems & Technical Chat 6 03-21-2007 11:12 PM
Spinning noise gradually increasing as RPM goes up joonoo Mechanical Problems & Technical Chat 0 09-03-2006 02:54 AM
Hard Drive-Like clicking noise heard... ntwrkguy Mechanical Problems & Technical Chat 2 04-16-2006 05:46 PM
