Kevin Briggs
Took off my calipers to get the powder coated. Went to put them back on and went through the whole process of bleeding and making sure the reservior did not run dry. Put all my wheels on and went to drive out of the shop and... I have no brakes. Pedal goes straight to the floor. You can pump it a couple of times and it will show some signs of braking but nowhere near what it needs to be. I even tried to bleed the master cyclinder. Is there something simple I am missing. I knew I should not have taken those brakes off to do this but I was being hard headed as usual.
#7 (permalink) | |
, but when you see the brake fluid coming through the line you need to keep pumping it until you don't see anymore bubbles in the line.
#10 (permalink) |
Sounds like you managed to get air in the master cylinder. You'll have to have someone with a vacuum unit purge the entire system. Had a similar thing happen to my buddy's EP3 on a track day.
Might be time to hit up a professional. Also, the bleed sequence is driver's front, and then proceed clockwise from there. Per Civic service manual. |
#11 (permalink) |
ButchMX!
I know this is a little off topic, but has anyone tried Speedbleeders? They're supposed to make bleeding brakes super easy.
Speed Bleeder Bleeding Brakes Bleeding Motorcycle Brakes Automotive Bleeder Screw Brake Bleeder |
#12 (permalink) | |
They work as advertised. Much easier than finding someone who can follow instructions. |
#13 (permalink) | |
I/E/RH NO REFLASH
pass side rear. driver side rear. pass front. driver side front. to the op, can you see any trace of fluid anywhere in the brake system>? |
#15 (permalink) | |
![]() You'd be right on most cars. Apparently the EBD has some fancy piping. |
#17 (permalink) | |
David
#19 (permalink) |
Kevin Briggs
It's at honda right now. E-braked it all the way on saturday morning. I will find out today what happened. I feel like an ediot. I have put on every part on my car including the s/c and I don't know how to bleed brakes...?! This does not sit well. with me.
#20 (permalink) |
Honestly, I would invest in a vacuum pump. They aren't that expensive. you can even get hand pump models if you look hard enough. That with speed bleeders will save you MANY headaches if you do your own brake service.
| oem Civic Si front brakes on my LX!! -impressions...(pics) | Andrei'sCivic | Suspension and Brakes | 67 | 07-15-2011 07:28 PM |
| weird anti-lock brakes? | carlossamano2004 | Suspension and Brakes | 23 | 10-10-2009 01:37 PM |
| Brakes upgraded to JDM Euro R Accord brakes | pengful | Suspension and Brakes | 32 | 08-19-2006 10:21 AM |
