What glue to use on window? - 8th Generation Honda Civic Forum
Old 02-28-2008, 03:38 PM   #1 (permalink)
av911's Avatar
My driver-side window is loose again.
Whenever I use the AUTO-UP function, the glass would fall out of place. I have to push the DOWN button so it'll sit back in place and then push the UP button to bring it all the way up.
The first time this happened (1 year ago), the regulator broke and I used some general purpose glue and I think/hope that it's the glue and not the regulator.
What kind of glue do you suggest using?? Here is a picture of where to apply the glue:
av911 is offline
Old 02-28-2008, 06:41 PM   #2 (permalink)
distrbd's Avatar
ken
I would try the special glue for reattaching rear view mirror,you know the type that comes in a small vial?
distrbd is offline   Reply With Quote
Old 02-28-2008, 06:43 PM   #3 (permalink)
Zeuceone's Avatar
warranty..?
Old 02-28-2008, 07:37 PM   #4 (permalink)
av911's Avatar
Originally Posted by Zeuceone View Post
warranty..?
Nah....48,xxx+ miles.
The first time it broke, I did bring it in to a dealership, while the car was still under warranty, and they said the window is not OEM, so it wasn't covered.(car was broken into twice)
I'll try what distrbd suggest.
Old 02-28-2008, 07:55 PM   #5 (permalink)
What material are the two clips made of?
I know Loctite makes a glue for difficult surfaces, such as nylon and plastics that a lot of glues won't adhere to...
I think its called Loctite Prism.
It's an instant glue kind of like crazy glue
Hope this Helps
Tom
BBdotcom is offline   Reply With Quote
Old 02-29-2008, 08:18 PM   #6 (permalink)
You cant use rear view mirror adhesive to atatch a sideglass. That glue is designed to break away on impact. Find,,3M Automix Channel Bonding and Sidelight Adhesive, on this link. It says you need a mixer gun but I have used it without it,, 3m - Product Category
Hyperion is offline   Reply With Quote
Old 02-29-2008, 08:22 PM   #7 (permalink)
Make sure you clean the glass clamps on the window regulator and the glass of all old glue.
Old 02-29-2008, 08:51 PM   #8 (permalink)
Survivor's Avatar
Check the PARTING OUT section. Someones selling justa bout everything one may need. Then it'll be OEM again!!!!
Survivor is offline   Reply With Quote
Old 02-29-2008, 09:34 PM   #9 (permalink)
Webby's Minion
8thgenuser's Avatar
Nikon Squad Member #8
This TSB might help you out.
U.S. & Canadian Tint Laws jc21 Inside and Out 46 06-17-2009 05:33 PM
Sedan Si Driver Window Problems... SIcivic07 Mechanical Problems & Technical Chat 1 09-03-2007 10:21 PM
Sticker Price Glue Stylinhonda Detailing 8 05-29-2007 11:15 AM
Drivers side window problems bskouby Mechanical Problems & Technical Chat 9 04-25-2007 12:43 AM
Removing Window Tint Glue SickSpd06Si Inside and Out 12 12-31-2006 12:20 AM
