Old 02-28-2008, 11:16 AM   1 links from elsewhere to this Post. Click to view. #1 (permalink)
ameuba10's Avatar
Question power steering failed
ok so i have a small problem. today when i was pulling into school something weird happened. it was like my power steering failed. all my electricals were on, but it took a ton of strength to turn it. and when i pressed the gas, it didnt do anything. then my oil light and my battery light came on. it was even harder to turn then. but i put it into park. cut the car off, and then back on. after that it was fine. does anyone know what the heck happened?
ameuba10 is offline   Reply With Quote
Old 02-28-2008, 11:40 AM   #2 (permalink)
mrbill's Avatar
You stalled.
-mr. bill
mrbill is offline   Reply With Quote
Old 02-28-2008, 11:41 AM   #3 (permalink)
Kill Your Self Krew
Zeuceone's Avatar
Originally Posted by mrbill View Post
You stalled.
-mr. bill
lol...
is Missy a squirter?
http://killyourself1.myminicity.com/tra build my city.
Old 02-28-2008, 11:43 AM   #4 (permalink)
8thcivic__my anti-drug
Truplatano's Avatar
Felix
isnt his car automatic
Truplatano is offline   Reply With Quote
Old 02-28-2008, 11:50 AM   #5 (permalink)
mrbill's Avatar
I don't know why it didn't hold idle, but that's what happened. The engine stalled.
-mr. bill
Old 02-28-2008, 11:58 AM   #6 (permalink)
cderalow's Avatar
Chris
-mr. bill
indeed...
odd for an auto to do it, but it does happen.
2008 Honda Civic Si Sedan Fiji Blue Pearl
FBP Crew #00
FA Crew #000
2007 Honda CR-V EX-L AWD Whistler Silver Metallic
HondaSUVForums Member
Old 02-28-2008, 12:30 PM   #7 (permalink)
ameuba10's Avatar
yea i have an automatic, and it had a full tank of gas. i have no oil leaks or anything. i wasnt drawing too much power, i had my volume on 3, and i didnt have the ac on...but im going to honda in a couple hours.
Old 02-28-2008, 12:32 PM   #8 (permalink)
I am Godzilla U R Japan
gotsnodooks's Avatar
Russ
Are you certain that you didn't stall and not notice?
Assassins do it from behind.
Mid Atlantic Crew #9
gotsnodooks is offline   Reply With Quote
Old 02-28-2008, 12:37 PM   #9 (permalink)
ameuba10's Avatar
how do you stall an AT?
Old 02-28-2008, 12:42 PM   #10 (permalink)
volvo9's Avatar
Andrew
You don't. It's nothing that you did. The car probrably let the engine rpm's drop too low and the engine quit. That's usually how automatic cars stall when your foot is off the gas.
Old 02-28-2008, 12:43 PM   #11 (permalink)
ameuba10's Avatar
it just kinda freaked me out when it happened. i didnt know what the heck went wrong. my bud thinks its either now oil, or bad fuel pump. but i havent had any other problems with it. im so lost...
Old 02-28-2008, 12:49 PM   #12 (permalink)
autos can stall all be it rare and random. doesnt mean theres anything wrong its just sometimes when you blip the throttle the revs climb a bit then if your completely off the gas when they drop back down they may drop past the idle range and the engine quits.. call it a brain fart on your ecu's part but i don't think theres anything wrong.
now if it does it once a month or something i'd get it checked out. cuz this should be like a once in a blue moon kinda thing.
vtecmike1 is offline   Reply With Quote
Old 02-28-2008, 12:52 PM   #13 (permalink)
ameuba10's Avatar
yea its never happened before. i just dont wanna be on a curvy back road and my steering goes out you know?
Old 02-28-2008, 01:11 PM   #14 (permalink)
its not gonna stall when the rpms are above 700rpms i think your good. your steering only failed because the car was off lol. and even then if your car did stall at lets say 40mph plus. you'd be able to steer no problem. lots of cars dont have power steering and although it does suck when the car is under 5mph being tough to steer you can do it just fine at a decent speed. its harder for a power steering car to steer once the system fails at low speeds cuz we have all the extra crap associated with power steering. but above 5-10mph you would be able to steer just fine.
you got the weight and enertia of the vehicle assisting you
Old 02-28-2008, 07:50 PM   #15 (permalink)
ameuba10's Avatar
what ya know, honda cant do anything for me. they said since it has only happened once, and there is no CEL's they cant do anything
Old 02-29-2008, 11:09 AM   #16 (permalink)
mrbill's Avatar
I'm sure they checked your idle speed and found it to spec too. No worries unless it happens again.
But it occurs to me.
Do you live close to school?
Was it cold outside?
Was the car cold (<150 degree F engine coolant temperature)?
Then you might want to check the intake air bypass control thermal valve and the vacuum hoses that connect between it, the intake manifold, and the far side of the throttle.
-mr. bill
Old 02-29-2008, 11:11 AM   #17 (permalink)
GlxyGry06Si's Avatar
mine does this but its when it really cold outside and its as soon as i start it. i turn the car off and then back on and it works. i dont know. what you think mr bill.
Old 02-29-2008, 11:20 AM   #18 (permalink)
Cr8tive_leo's Avatar
Adrian
Stalled, also a weak battery could cause this (or bad alternator causing the weak battery) so many things that accumulate to cause a failure.
It's happened to me once with my Civic, and a lot with my old blazer. (Blazer had a fuel pump issue, batery and a long list that made me buy the Civic! WOO!)
Cr8tive_leo is offline   Reply With Quote
Old 02-29-2008, 11:44 AM   #19 (permalink)
ameuba10's Avatar
i live 20 miles from school, so my car was good and warm by the time i got there
Old 02-29-2008, 12:56 PM   #20 (permalink)
mrbill's Avatar
Almost didn't want to mention the intake air bypass control thermal valve. So ameuba10, just chalk it up to a gremlin, or I agree with Creative Leo, a combination of small things leading to a stall. You should *not* stress out about this until it happens more than once in a blue moon.
GalaxyGry06SI, first, "really cold" in Jacksonville is how cold?
Every time it's cold?
Sometime's when it's cold?
Either way, you say it only happens once, then it's fine? Then it's almost certainly not the bypass. You have enough intake mods and gaskets you definitely want to make sure that IF you've done a throttle body coolant bypass to be aware of the consequences on rare "really cold" days.
-mr. bill
LinkBack to this Thread: http://www.8thcivic.com/forums/mechanical-problems-technical-chat/81549-power-steering-failed.html
8th Generation Honda Civic Forum This thread Refback 02-29-2008 03:45 PM
Power steering went out slickciv Mechanical Problems & Technical Chat 5 12-04-2007 12:05 PM
Skunk2 Mega Power Exhausts Skunk2.com Bolt-Ons And All-Motor 50 10-15-2007 09:29 PM
power steering mrfabulous Mechanical Problems & Technical Chat 3 08-19-2006 06:21 AM
Power Steering Problem daveswift Mechanical Problems & Technical Chat 0 07-19-2006 01:35 AM
