okie my car has only 2500 on with the new clucth i'm begining to notic that when my car is off i push down on the clucth it make sqeake nosie. The other thing is my clucth is gettign softer (ez to push down on) is that normal ? and the last quesation that i have is when i push down on the clucth it feel liek the clucth is moving is that normal?
First, compose your questions a little better.
Everything you described is normal. I'm wondering why you have a brand new clutch at 2500 miles. Now, read up on how to drive a car equipped with a manual transmission. Clutch is supposed to be spinning because thats just what it's doing in there! I get the squeeking noise often or did when the clutch was newer. It's normal. As far as softer, I don't exactly know what you mean by it. |
did they install a new throw out bearing? or lightly grease it before reinstalling in? the Squeek may be the TOB.
Spongy clutch may be due to them not properly bleeding your clutch. If you had a clutch master cylinder replacement, you need to readjust the pedal to prevent the clutch pedal from binding up. Hope this helps. For future references, please type in clear and concise english if you are seeking assistance. This makes it easier to read and probably yield more responses. |
#8 (permalink) | |
Too Sleepy.
| need help ASAP!!!!!! | micyj30 | Mechanical Problems & Technical Chat | 11 | 01-16-2008 01:26 AM |
| New Here; Need Help ASAP!! | ecotecon18s | Civic Coupe And Sedan | 6 | 01-08-2008 12:56 AM |
| Help Asap!!! | ominous8204 | Water Cooler | 8 | 04-27-2007 10:41 PM |
| NEED HELP ASAP!! | 06RALLYREDSI | Inside and Out | 4 | 04-05-2007 02:16 PM |
| NEED TO KNOW ASAP!!!!!! | bboylocob | Wheel And Tire Upgrades | 5 | 01-18-2007 04:58 PM |
