engine revving at idle
While driving an 08 lx home today, I stopped at a red light and the motor started racing up and down( about 1.5k to 2k) and when I took off there was no power. After pulling in a parking spot and turning the engine off, the car restarted and ran fine, but I had a cel. has anyone seen this before or have an idea what the cause is? The mods are a k&n intake, megan downpipe, magnaflow exhaust, and they have all been on the car for over a 1k miles.
Well at no point did it overheat, and I was in the middle of a 20-mile commute. I checked everything under the hood, but nothing was loose. I reset the ECU when I got home and it seemed to be fine...I guess we'll see. If it comes up again I think I'm with you asif.
id check your intake/manifold to see if theyre sitting tight and that everythings working properly. i dont have LX so i cant really be much help, but the Si's have some issues in the cold, and if your a/c is on at a light your tach can bounce a little bit occasionally...but i dont think thats what your talking about..
#12 (permalink) | |
Coolant level MAF(mass air flow sensor) Vacuum leak and the most common item in this case the IAC (idle air control valve) |
| Dude screaming at Porsche GT owner revving | Skylinegtr06 | Garage | 20 | 07-20-2007 08:17 AM |
| K20 Revving to 11,000 RPM Curtesy of Spoon | MrPanther | Forced Induction And Nitrous | 65 | 01-14-2007 06:59 PM |
| Revving! | 403civic | Mechanical Problems & Technical Chat | 13 | 11-04-2006 07:00 PM |
| Engine Knocking at idle | bmw325 | Mechanical Problems & Technical Chat | 4 | 07-12-2006 06:27 PM |
| civic ex cp engine knocking sound on idle | oplok72 | Civic Coupe And Sedan | 35 | 05-03-2006 11:00 AM |
