Old 02-25-2008, 02:41 PM   #1 (permalink)
civicracer32's Avatar
Advancing the timing on an R18 to run Premium
Can it be done on the R18 like on older civics?
civicracer32 is offline   Reply With Quote
Old 02-25-2008, 02:57 PM   #2 (permalink)
Not at present since there is no engine management system available or even a piggy back at this time that would allow you the ability to adjust the timing. Granted, Greddy has their V-Manage that is suppose to provide this functionality, but I don't think it is available yet.
blueroadster is offline   Reply With Quote
Old 02-25-2008, 03:01 PM   #3 (permalink)
Ct_Sidan07's Avatar
^^^ he is talking about advancing the timing on the distrubutor...which i dont think they have
Ct_Sidan07 is offline   Reply With Quote
Old 02-25-2008, 03:04 PM   #4 (permalink)
n00b retro whore
ethlar's Avatar
no distributor on r18s, coil packs
if you run premium on the car it might advance the timing some automatically, but i honestly have no clue
Old 02-25-2008, 03:27 PM   #5 (permalink)
SRT4toCivicSi's Avatar
Kendrick A. Hanson
anything is possible with a tuning device, tuning, and money...
SRT4toCivicSi is offline   Reply With Quote
Old 02-25-2008, 06:00 PM   #6 (permalink)
Thanks guys.
Old 02-25-2008, 09:07 PM   #7 (permalink)
Kendrick A. Hanson
Personally I wouldn't do it unless you plan on making your car a race car of some sort. Plus, it'll void any warranty you have. Don't know if thats a concern for you or not though...
Old 02-26-2008, 01:09 AM   #8 (permalink)
The ECU will adapt somewhat. I do get a shade better performance when using premium.
sandeep108 is offline   Reply With Quote
Old 02-26-2008, 02:54 AM   #9 (permalink)
Kidekat's Avatar
Prove it....
Stick to 87. Unless you are boosted, on the bottle, or are running higher than factory compression.
Kidekat is offline   Reply With Quote
Old 02-26-2008, 10:38 AM   #10 (permalink)
Kidekat is right on. Your map will have a preset maximum advance it will run. If it detects knock it can retard the timing to prevent damage to the engine, but it won't advance it. Basically, it doesn't know you put premium in it, it just knows its not detonating.
OhondaU is offline   Reply With Quote
Old 02-27-2008, 01:09 AM   #11 (permalink)
Originally Posted by Kidekat View Post
Prove it....
Difficult to. I just know that my engine feels smoother, quieter and with a bit more low end grunt with 'premium' than with regular.
I should qualify this by saying that where I live, while gas quality has improved, due to various factors, 91 is still possibly only 86-87. I actually mix 97 (yes, we do get 97 at a few pumps) with 91(87?) 1:3 and achieve this. It costs me about about 2 $ more per tank and have not observed any ill effects so I continue. But 97 by itself does not feel any much better than this mix and actually I feel the engine does not like it. At another pump, I do get ready 91 premium too, which has much the same effect as my mix.
I do suggest you try it for yourself and see, since IMO premium cannot otherwise harm the engine/fuel system.
Do you have to run premium in the SI? MPG questions.... SixFeetDeep Civic SI 1 01-09-2008 06:54 PM
Premium gas in R18?? pks17 Mechanical Problems & Technical Chat 3 11-01-2007 07:58 PM
REG or PREMIUM fuel on 10.5:1 R18?? pks17 Civic Coupe And Sedan 1 11-01-2007 07:57 PM
retard ignition timing on r18? mysticdx Forced Induction And Nitrous 3 08-15-2007 05:25 AM
