Old 05-27-2006, 01:56 PM   #1 (permalink)
maintenance minder
Can you guys explain to me how this works? This sounds retarted but i cant figure out how to use the maintenance minder. I looked in the guidebook and an indicator that looks like a wrench lights up whenever i start my car and then goes off but thats all ive seen. How can i tell the what the precentage of the oil life is? Thanks guys
lifeguard is offline   Reply With Quote
Old 05-27-2006, 02:11 PM   #2 (permalink)
Skyline's Avatar
When the car comes on and the wrench shows up, there should be a letter. Look that letter up in your manual, and it will tell you exactly what to do.
You oil life can be found by hitting the sel/reset button until it shows up. It will have a percentage next to it.
If the maintenance minder is telling you to change the oil, then it should show the percentage automatically when you start the car, and the wrench won't go away until you hit the sel/reset button to go back to your trip meter.
Skyline is offline   Reply With Quote
Old 05-28-2006, 03:48 PM   #3 (permalink)
n00b retro whore
ethlar's Avatar
i have a really stupid question
If you change the oil and reset the oil life, does that reset the maintenance interval too?
Old 05-28-2006, 05:13 PM   #4 (permalink)
Skyline's Avatar
Your maintenance interval should be fine.
Old 08-08-2007, 12:01 AM   #5 (permalink)
darryl
oil life/trip meter question o7 civic
we have misplaced our manuel and i have an 06 civic that has almost 6000
miles on it and i changed the oil the first time at a little before 3000 and now this time a little before 6000.
my problem or question is that i had made a little road trip and wanted to set a trip meter and somehow i made this wrench icon appear every so often and the percentage of oil life before change?
how do i reset this and can i order a replacement owners manuel?
thanks for any help people.
darryl
uglystikr is offline   Reply With Quote
Old 08-08-2007, 12:10 AM   #6 (permalink)
Scrodums
Yodums's Avatar
HIRO - ಠ_ಠ
9. Press the sel/reset button untill the oil life monitor comes up, hold the sel/reset button for 10 seconds, the oil life will start to blink, press and hold the sel/reset button for 5 seconds to reset the monitor.
You shouldn't need to change the oil that frequently. Assuming you're using synthetic oil, it is totally unnecessary. You can easily push today's synthetic oils to 10,000 miles without any issues.
Old 08-08-2007, 12:13 AM   #7 (permalink)
GlxyGry06Si's Avatar
really. i change it about every 2500-3000. i ride her rough tho.
Old 08-08-2007, 12:14 AM   #8 (permalink)
Firestrife's Avatar
Keenan
yea man those synthetics are too expensive to change that often.
Firestrife is offline   Reply With Quote
Old 08-08-2007, 12:16 AM   #9 (permalink)
yeah its about 50 bucks every month and a half
Old 08-08-2007, 12:18 AM   #10 (permalink)
Scrodums
Yodums's Avatar
HIRO - ಠ_ಠ
This thread touches on the topic of OCI (oil change intervals): Dealership says i can switch back to regular oil if i want....
Old 12-04-2007, 12:52 PM   #11 (permalink)
Jason
two questions:
1. lets say i change my oil a bit early than what honda recommends (i.e 4.5 k rather than 5k). after the second oil change i would have 9k miles, so would the wrench icon appear after i hit 10k (only 1k miles after the second oil change)?
2. do either one of the letters for the wrench icon REQUIRE servicing at the dealership or just some stuff i can do myself?
Old 12-04-2007, 01:35 PM   #12 (permalink)
ryker's Avatar
Why doesn't anybody read the owners manual? Or vist honda.com owners link?
ryker is offline   Reply With Quote
Old 12-04-2007, 01:37 PM   #13 (permalink)
ryker's Avatar
Originally Posted by AllShowNoGo View Post
two questions:
1st Honda doesn't recommend any set oil change interval based on mileage.
After each oil change your supposed to reset the "maintance minder".
ON the second question. If you are unable to read the owners manual then your probably best off taking it to the dealership.
Old 12-04-2007, 04:25 PM   #14 (permalink)
+1!!
Old 12-04-2007, 05:08 PM   #15 (permalink)
8thcivic Sponsor
Z1 Performance's Avatar
And the maintenance minder is based on the assumption that you're using conventional oil, not synthetic.
The ECU calculates oil life % based on how you drive...it has no idea how "dirty" oil is.
Jonathan
www.z1auto.com
631-863-3820
Check out our BLOG for:
Z1 Performance is online now   Reply With Quote
Old 12-04-2007, 05:14 PM   #16 (permalink)
basically its an educated guess on the computers part.
Old 12-05-2007, 12:07 PM   #17 (permalink)
ryker's Avatar
true. The ECU knows that X amount of fuel has been burnt in the engine. Based on years of lab testing by many car makers -they know that oil life can be judge by fuel useage.
The ECU is unable to detect a cheap air filter allowing in dirty air or cheap gas or mechanical problems.
Old 12-05-2007, 12:54 PM   #18 (permalink)
Jason
why not write something useful and not bash on other people?
Old 12-05-2007, 12:59 PM   #19 (permalink)
ryker's Avatar
http://www.8thcivic.com/forums/search.php
Old 12-05-2007, 01:00 PM   #20 (permalink)
Jason
^now ur learning
Where do you go for scheduled maintenance? Dealer, Do-It Yourself, or Other? CivicCilla Garage 31 09-29-2008 02:40 AM
