Old 02-24-2008, 02:44 AM   #1 (permalink)
drivers window screeches
Well I removed the stupid warning sticker from the driver window and cleand the sticker residue with a razor blade and windex. And now when I roll the window down I don't have a problem but when I roll it up it screeches like a mother f**kn nails on a chalk board and I can't figure out what it is. Any ideas what it could be?
Thanks in advance
luey
bigluelok is offline   Reply With Quote
Old 02-24-2008, 04:13 AM   #2 (permalink)
most likely left over residue... pull back the rubber thing at the base of the window and clean it with some detergent/old toothbrush. Then clean your window (in/out) again for good measure.
If the detergent does not work, try Goo Gone... works like a charm
habitat is offline   Reply With Quote
Old 02-24-2008, 02:02 PM   #3 (permalink)
remz857's Avatar
Jim
well get some window washer and wash it again. Thats weird, i've never heard anything like that. Maybe you can take it to your dealer if it dosnt go away. Hope everything turns out ok for you buddie.
remz857 is offline   Reply With Quote
Old 02-24-2008, 04:43 PM   #4 (permalink)
I took it to the dealer so they could check it out but they said I would have to bring it back in the am and leave it all day and I couldn't do theat because I had to work.
Old 02-24-2008, 04:47 PM   #5 (permalink)
Jason
it's gonna take the dealership all day long to figure out that it's left over residue from the warning sticker? right. ur honda dealer sux.
i took my sticker off as well and got the same noise. i did gently scrape off the leftover gunk with a razor blade and then applied windex to it and got all of it off.
will the civic drivers get the "vtec experience" as the Si drivers do? jl33 Civic Coupe And Sedan 90 11-14-2008 07:15 PM
KY Cops/Truck Drivers Bust Aggressive Drivers CameronJr9 South 4 07-06-2008 10:06 PM
Drivers auto window feature stopped working bruzzac Mechanical Problems & Technical Chat 10 03-31-2008 08:50 PM
Drivers side window problems bskouby Mechanical Problems & Technical Chat 9 04-25-2007 12:43 AM
Drivers window has gone crazy Lek Mechanical Problems & Technical Chat 2 05-06-2006 09:33 PM
