CEL, even with defouler?
I'm having a really odd situation. I've had my RH on for probably about two months. Never had a single issue with it, recently the flexpipe started to crack a bit, which was expected since it's a dc setup. I ordered a new bigger flexpipe that i'll be welding in place pretty soon. But, recently my check engine light came on, a buddy of mine came over with his ODB-II reader and i can't remember the code but it had something to do with the o2 sensor in bank two? I believe. I'm not entirely sure.
Could the exhaust leak in the flexpipe be causing the CEL? The weird thing is, If I reset the battery and just drive the car normally -- it doesn't go off, no matter what. The minute I drive "spiritedly" it goes on about ten minutes later. I haven't done any mods recently except a skunk2 70mm exhaust which definitely isn't the cause. Does anyone have any suggestions on what I should do or is it pretty much caused by the leak? |
#2 (permalink) | |
Mr. Cowl Induction
![]() Join Date: May 2007
Wild VTEC'n Bill
Do you have a defouler now? That exhaust leak could definitely be screwing things up for you. Get that flexpipe fixed and I would go with an angled defouler, if you don't already have one.
| What is a defouler? | A970747 | Mechanical Problems & Technical Chat | 10 | 02-23-2008 09:41 AM |
| defouler installed.....CEL light still on!! | G-Ray | Mechanical Problems & Technical Chat | 10 | 01-14-2008 03:15 AM |
| Defouler | GlxyGry06Si | Bolt-Ons And All-Motor | 10 | 06-27-2007 06:41 PM |
| DC race header - defouler cel light mod fix | jdmk20z3 | Civic SI | 1 | 04-04-2006 06:28 PM |
