Old 02-23-2008, 04:44 PM   #1 (permalink)
borabora1989's Avatar
Oil light
i just changed my engine oil cause the life was at 15% and the little maintenance light is on. Now that the oil change and filter is done the light go away. The manual says the dealership can reset it for you. Does anyone know how to reset it yourself?
borabora1989 is offline   Reply With Quote
Old 02-23-2008, 04:45 PM   #2 (permalink)
HondaTune's Avatar
IDK I don't own a ODB2 car w/ all these lights and bullshits. But try pressing the brake pedal 3 times then holding the lil button to reset your trip distance.... OR something like that
HondaTune is offline   Reply With Quote
Old 02-23-2008, 04:55 PM   #3 (permalink)
8th Civic Addict
msjwild3's Avatar
Ryan
well you can reset it yourself. You turn your car off, then click the key 2 times to where the car is not on but all the lights and stuff are on, then hit the select button until you get to the screen that shows your oil life %, then hold the select button in for i think its like 10-15 seconds, it will start flashing, then hold it in again and it will change back to 100% and your good. It's that easy. It should turn the maintnance light off too.
msjwild3 is offline   Reply With Quote
Old 02-23-2008, 05:02 PM   #4 (permalink)
fox
fox's Avatar
Andrew
aye this is correct as it reads on page 214 in the 2007 owners manual.
read the manual!
fox is offline   Reply With Quote
Old 02-23-2008, 05:03 PM   #5 (permalink)
8th Civic Addict
msjwild3's Avatar
Ryan
read the manual!
Ya read the manual, it's in there. Usually when I have a problem I check my manual first, that's what its there for!
Old 02-23-2008, 08:26 PM   #6 (permalink)
Jason
read the manual!
i would bet money that this dude has this memorized from answering this questions MULTIPLE times on this forum.
to the OP, yes you can reset it yourself, but please do a search next time and/or read the manual. you paid good $$ for that book, so take advantage of it.
Old 02-24-2008, 01:17 AM   #7 (permalink)
lol my cousin looked in it for me. i have an 08 and it said the dealership can do it for me. So im thanking fox for his help and it did work. so sorry for my lazyness to read but thanks
check oil light bray815 Mechanical Problems & Technical Chat 4 02-12-2008 05:15 PM
SI Oil Light Question DinoSI Civic SI 21 01-14-2008 08:35 PM
oil light reminder, do they turn off when you replace the oil? cbizz Mechanical Problems & Technical Chat 5 01-25-2007 12:02 PM
change oil light. BigGreg030 Civic SI 2 12-22-2006 07:07 PM
battery light & oil light came on - what did I do? shewrites Mechanical Problems & Technical Chat 7 12-30-2005 12:47 AM
