Old 02-18-2008, 05:22 PM   1 links from elsewhere to this Post. Click to view. #1 (permalink)
e60.deluxe's Avatar
Removing motor/mirror from assembly?
ya so someone clipped my mirror and its got a scratch and some white paint on it, so im just gonna order a replacement cap online for $12.70.
but my question is i know that i have to release 6 clips in the back of the assembly to remove the cap, but, how do i remove the mirror/motor to do so?
e60.deluxe is offline   Reply With Quote
Old 03-01-2008, 01:28 PM   #2 (permalink)
e60.deluxe's Avatar
ahh, whatever i figured it out. i only wish i had known i would have needed a T10 before i removed it from the car. i only had down to a T15 in my torx set...
Old 03-01-2008, 04:47 PM   #3 (permalink)
07civicex's Avatar
Matt
So how did you remove the mirror? And how did the cap come off?
07civicex is offline   Reply With Quote
Old 03-01-2008, 04:58 PM   #4 (permalink)
e60.deluxe's Avatar
you just pull the mirror and it snaps off. there is a circle type thing on the motor and it has 2 clips one at 2 o clock and another at like 7. the back of the mirror has the same clips. you just yank it off and snap it back in.
once you do that. you take out like 3 torx screws, you remove the motor from the motor bracket it guess you would call it. leave it dangling, you dont need to remove the harness connector from the motor bracket.
then on the side where the mirror attaches to the car, you remove this foam padding, and then there are 2 more torx screws that hold the motor bracket into the enclosure. you can then slide it out laterally and pull it, and the motor out afterword.
now you should have the black plastic shell and the painted cap.
cap uses 6 clips i knew that. you have to pop them off with a scredriver from the area underneath the motor.
then reverse.
Old 06-02-2008, 10:06 PM   #5 (permalink)
07 Figi Blue Si's Avatar
Lance
Looking for this.
THKS
07 Figi Blue Si is offline   Reply With Quote
LinkBack to this Thread: http://www.8thcivic.com/forums/mechanical-problems-technical-chat/79695-removing-motor-mirror-assembly.html
8th Generation Honda Civic Forum This thread Refback 02-18-2008 05:25 PM
Removing mirror from side mirror housing... tarh33l10 Mechanical Problems & Technical Chat 10 08-15-2008 01:15 PM
3 STAGE I-VTEC, Electrocharger, Electric motor EVO (1520tq), Air Motor k20guy Forced Induction And Nitrous 17 06-03-2007 12:38 PM
removing rear view mirror button supersly_jones Mechanical Problems & Technical Chat 0 12-21-2006 11:12 PM
mirror mirror on the wall who is the sickest of them all? boostedg35 Introduction & Pictures 48 07-09-2006 05:04 PM
