Old 02-15-2008, 06:39 PM   #1 (permalink)
adamzeppelin's Avatar
Adam
Gas Tank Release Lever!!!
So, my gas tank release lever won't unlock! I had to pry the thing open with my key and scratched my paint a bit. I have done as many searches as I could to find a thread with this problem, but I think I might be the first? Anyway, any thoughts, suggestions on doing it myself, because I know i can take it to the dealer I would just rather not. thanks....
adamzeppelin is offline   Reply With Quote
Old 02-15-2008, 06:43 PM   #2 (permalink)
Adam
anyone with a little knowlege be able to help? maybe?? many thanks
Old 02-15-2008, 06:47 PM   #3 (permalink)
Rasky's Auto Detailing
RaskyR1's Avatar
There is a secondary release in the truck....you try that?
^Meguiars Junkie
8thgen Meet at Rasky's June 21st!!!
RaskyR1 is online now   Reply With Quote
Old 02-15-2008, 06:53 PM   #4 (permalink)
"Tuck a Benjamin"
boost1320's Avatar
Brian
Originally Posted by zippob09 View Post
yeah just send me $5000 cuz you're stupid and dumb and lame. Jerk. Ass bag. You suck, go home, don't come back to this forum.
boost1320 is offline   Reply With Quote
Old 02-15-2008, 06:58 PM   #5 (permalink)
Adam
No, how and where do you access it? is it in the manual?
Old 02-15-2008, 07:00 PM   #6 (permalink)
Adam
I went into the trunk and popped a couple of the clips off and took a look, but all I could see were the cables that are like those bicycle brake cables...but I didn't see a secondary release?
Old 02-15-2008, 07:03 PM   #7 (permalink)
RaskyR1's Avatar
I'm pretty sure it was on the left side in plain view, if not the manual should show where it is.
I think it was a little black platic handle on the end of a wire cable.
^Meguiars Junkie
Old 02-15-2008, 07:06 PM   #8 (permalink)
Adam
alright, thanks, I'll check it out tomorrow when there is more light...hopefully I will figure it out myself so I don't have to go to the dealer...or do you think if I have to access the secondary release that it is inevitable that I will have to take it to the dealer?
Old 02-15-2008, 07:17 PM   #9 (permalink)
RaskyR1's Avatar
So did you lock it with the key and now it won't unlock? Are you using the valet key or the main key?
^Meguiars Junkie
Old 02-16-2008, 12:06 PM   #10 (permalink)
Adam
I didn't lock anything...the trunk opens just fine, with the button on the key and with the lever on the left side of the drivers seat. It's the gas cap release part of the lever that isn't working. The keyhole where you can lock the trunk is in the unlocked position. I think the little metal head at the end of the cable somehow became unhooked from the opening device that pulls the little peg thingy to unlock the gas cap...gonna have to take a look I think.
Old 02-19-2008, 05:54 AM   #11 (permalink)
oHsevenGG_Si's Avatar
I actually had this problem... so you're not alone. However; mine came from taking the assembly off when installing power wires for my amps. Then the assembly wasn't put back on fully and correctly. Just take off that plastic cover and you'll be able to see how it works and honestly by looking at it you can place it back together correctly just make sure when you're tightening the screw or bolt or whatever (its been awhile) that you push down all the way making sure theres contact.
oHsevenGG_Si is offline   Reply With Quote
Old 02-19-2008, 10:12 AM   #12 (permalink)
volvo9's Avatar
Andrew
Open the gas door and have someone pull the lever, you will see a little plastic piece move in and out, it should retract fully when the lever is pulled, letting the gas door unlock, if it does not then the cable is out of adjustment.
Another situation is when the lever works properly but either the spring which pops the door open is weak or snapped or the hinges are bound up from paint, corrosion or rust.
Old 02-19-2008, 12:02 PM   #13 (permalink)
radiocontrolhead's Avatar
Danny
Half the threads here were misinterpreted and thought you were talking about your trunk. He's talking about his gas tank cover guys. NOT TRUNK!
Old 02-19-2008, 12:13 PM   #14 (permalink)
emopains's Avatar
Marcus
Take your lemon down to the dealer and stop being ghetto everytime u need to fill up
emopains is offline   Reply With Quote
Old 02-19-2008, 12:29 PM   #15 (permalink)
RaskyR1's Avatar
I don't see a single post that thinks he's talking about the trunk...
^Meguiars Junkie
Old 02-19-2008, 01:49 PM   #16 (permalink)
emopains's Avatar
Marcus
Old 02-19-2008, 04:36 PM   #17 (permalink)
Slutty McSlut Slut
cderalow's Avatar
Chris
one should note you have to push the lever down, and not pull to open the gas tank....
2008 Honda Civic Si Sedan Fiji Blue Pearl
FBP Crew #00
FA Crew #000
2007 Honda CR-V EX-L AWD Whistler Silver Metallic
HondaSUVForums Member
Old 02-20-2008, 03:06 AM   #18 (permalink)
emopains's Avatar
Marcus
Supposidly the lever doesn't work.
Cable has been severed.
My guesstimate... crazy ex-gf
Gas tank mito Garage 17 02-12-2008 02:50 AM
How far on a tank of gas? zenith931 Driving Experience 1 05-18-2007 08:02 PM
Through the first tank of gas schield Civic SI 25 05-03-2007 02:17 AM
empty gas tank truflip Water Cooler 24 01-27-2007 02:02 PM
