Old 02-15-2008, 08:45 AM   #1 (permalink)
Rear Defroster
So my rear defroster used to work excellent!! Used to that is! My girl takes my car for a while on wednesday while I was working and at the end of the day she picks me up and first thing i notice is my rear defroster is on. She said she must have hit it while messing with the temp control...well I do know she hit it cuase there is no way I would have left it on. To get to the point, now the past two days when i turn it on first thing in the morning it doesnt work like it used to. It works but takes literally 5 times longer than it did to clear my window up. Does running it on a dry window for a period of time burn it out? Thanks for any help.
JoeKool is offline   Reply With Quote
Old 02-15-2008, 12:46 PM   #2 (permalink)
Duce2k's Avatar
It shouldn't, the rear defogger is on a timer so It doesn't stay on longer than it should, I ususally turn mine on only once and let it turn off on it's own, if you're concerned take it in to the dealer
Old 02-15-2008, 11:53 PM   #3 (permalink)
The McGyver ofall McGyves
portabuddy's Avatar
Bart Koscow
mine when on dirupts the radio so i dont turn it on anymore... i used to work well, but hasnt been turned on for atlease a year now...if i turn it on all i here from the radio is static.
#@$$ TINTKING mother@#$!ERS!!!
Check out my 10.5" touch screen CarPuter install
Life dosn't have a reset button, if it did you may as well turn the game off.
Originally Posted by George Carlin
"Its called the American dream, because you have to be asleep in order to believe in it."
portabuddy is offline   Reply With Quote
noise from rear... hfp suspension and progress rear sway bar rippars Mechanical Problems & Technical Chat 8 07-01-2008 09:42 PM
when you have the defroster on dnbsi Civic SI 39 01-03-2008 03:48 PM
rear defroster top part wont work? 20civic07 Mechanical Problems & Technical Chat 4 12-26-2007 05:02 PM
JUST installed my Raybrig rear fog light and my si rear sway bar mistergizmo007 Introduction & Pictures 52 11-29-2007 02:23 AM
Question About Tinting Rear Window And Using Rear Defroster! joe8thcivic Civic Coupe And Sedan 9 05-28-2007 11:27 PM
