Old 02-12-2008, 01:28 PM   #1 (permalink)
08 Civic LX Automatic - Grinding or Vibration off the gas pedal at around 20 mph
Hi,
I might be paranoid but when I'm at about 20 - 25 mph I feel a vibration or grinding coming off the gas pedal. As the car accelerates to a higher speed and changes gears, again you feel the same vibration or grinding coming off the gas pedal. Now it has nothing to do with the pedal but most likely something off the engine. Sorry for not being technical enough.
Has anyone else experienced this? Is this normal? Any help appreciated.
Thanks.
nhip101 is offline   Reply With Quote
Old 02-12-2008, 02:15 PM   #2 (permalink)
I feel the same with my civic i just purchased it, it is also a 2007 honda civic 4 door lx auto. I think its the gridning is normal due to the fact of the cars engine being so compact.
ikhan is offline   Reply With Quote
Old 02-12-2008, 05:50 PM   #3 (permalink)
Thanks for the reply. It's such a irking feeling when you buy a brand new car and you start noticing the little things.
I feel a little better though I don't remember the vibration or grinding until now.
Old 02-12-2008, 08:29 PM   #4 (permalink)
its nothing big, i have turned off my radio and heater just to listen to see if the grinding was coming from the engine but the engine sounds like new no knocking or gridning, i personaly think the pedal grinds due to vibration.
2008 Honda Civic Jerky Automatic Transmission between 10-15 mph Matrix454 Civic Coupe And Sedan 93 11-19-2008 09:00 AM
Throttle reaction/gas pedal vibration? 06CivEXJon Mechanical Problems & Technical Chat 7 05-10-2008 01:45 AM
Vibration from the gas pedal devil899 Mechanical Problems & Technical Chat 1 10-25-2007 11:17 AM
07 Civic Si Sedan Gas Pedal Vibration GoldenBoy Mechanical Problems & Technical Chat 3 06-21-2007 11:48 PM
Gas pedal buzzing/grinding feel past 3500rpm TdotSi Mechanical Problems & Technical Chat 0 06-06-2007 06:17 PM
